Well guess adding airbags
Nicholsfamily05
So I compared my old truck to the new truck we have.
Last one was the 2500 Mega cab but had air bags.
New one 3500 crew cab does not have any.
It rode great on the way to the dealership, thinking I'm going to add them as we pick up the new trailer in the morning and it weighs a bit more than the last.
What do you all think.
Have only towed the old trailer from our house to the dealership for repairs so approximately 40 miles with the new truck.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
14 REPLIES 14
transamz9
The thing with the SRW 3500's is they don't have the typical overload springs on the top that engages. The overload spring is one thick leaf on the bottom. OP , that truck will be just fine that way. I believe you'll be pleasantly surprised at how well it will handle and ride like that. My 2013 was the same way and honestly I liked the way it handled the load better than my 2016 Mega cab with the auto air leveling.
Here's the 13's stance loaded........
Here's the 16 with the same load. Again, although the 16 looks better riding at the original ride height I liked the ride and handling of the 13 better..
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
Nicholsfamily05
The New 3500 does sit higher than the 2500.
Just from comparing the two different trailer as well I think the one Older Crossroads Cruiser sits higher than the new Sierra we are going to pick up. Could just be the way the shop has them parked but to me I felt like I had to duck a bit more to go under over hang.
The new Sierra all the storage is up front except for a spot under the rear bed. So the pin weight should go above what they have listed as 2250lbs. We also get a new hitch today as well so have to see about adjustments there.
Going to snap a few photos of it and I'll put them up to compare as well. Then work on the adjustments to get hem level.
rhagfo
So what I see is the new 3500 sits higher at the TG than the 2500. With the 2500 the 5er looks level, with the 3500 the 5er looks a little nose high, which can make the TV look a bit down in the rear.
If you lad the new 5er with 1,000# of stuff pin should go up about 250# tor 2,500#, what does the current pin weigh.
Threebigfords
I'm assuming the second pic is the new truck, and yes I can see the difference in the rear ride heights.
I know according to some on here, only Ford's squat under a load, but I agree with you that if that's your old trailer, and the new one is heavier, I'd be investing in a set of bags.
Just the versatility of being able to set the right height based on how you load your gear in the trailer would be worth it in my opinion.
Coming from the bumper pull toyhauler side of things, my tonque weights can vary greatly depending on how or if I load the toys/tanks/gear. The same trailer can have anywhere from 1200-2200lbs of tongue weight. Add to that, sometimes the truck bed is empty, other times it has 3000lbs in it plus the trailer tongue weight.
15' Ford F450 4x4 Platinum Bronze Fire Metallic
17' Ford Explorer Platinum 3.5 Ecoboost Ruby Red Metallic
78' F250 SC LB 4x4 - highly modified
2003 Weekend Warrior FS2600 toyhauler and the toys to fill it
1997 10' Northland Grizzly 990 Ext Cab
Grit_dog
Nomad III
Nomad III
From the pics it looks a little nose high. My personal pref would be to stiffen it up a bit. Wouldn't take much air. Some stable load type spacers would even do the trick. Just to get the overload leaf involved a little quicker.
SoCalDesertRid1
Looks alright to me.
If it needs anything more, I would add a leaf to the overloads. It doesn't affect the unloaded ride and both raises and firms up the loaded ride.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Cummins12V98
After hooking up fully loaded the truck should sit LEVEL, if so leave well enough alone!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
kw_00
Looks normal to me, I would not spend the money unless it was really needed. Btw that's a really nice truck!
A truck, a camper, a few toys, but most importantly a wonderful family.
Nicholsfamily05
Well we pick up the new one tomorrow a Sierra 377flik
Says the weight should be 2250.
Since our other trailer gave issues all summer long we will only get maybe two more trips before we are done.
Mostly because of school for the kids and our work schedules, but we will see how it goes.
alboy
You would need at least 3500 lbs of pin weight to even begin thinking of adding bags.Your truck likely has somewhere between 3700-4200 payload, as long as your under your rating,there is nothing to be gained.
Strabo
Looks fine to me. Our '04 F350 has factory 6 spring pack plus overload springs, sits perfectly level with our 13,000lb toyhauler. No air bags needed.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
Greene728
Why would you not try it first and see how it does before spending the money?
2011 Crossroads Cruiser 29BHS ( Traded )
2017 Grand Design 303RLS ( Sold )
Currently camperless ( Just taking a break )
2016 Chevy Silverado 2500 4x4 6.0 and 4:10โ€™s
Me and the wife and our two daughters. Life's good!
Greene728
bbaker2001 wrote:
what does my ram 2015 3500 not come with airbags. I thought It was a law
Huh?
Why would it be a law?
You can get either factory bags or springs.
bbaker2001
delete
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
