Jan-12-2014 01:41 PM
May-26-2015 06:13 PM
grizzly8 wrote:
SAME THING IS HAPPENING ON MY 2012 WOLFCREEK 850 LB I HAVE CALLED NORTHWOOD ABOUT FIXING IT AND THEY SAID ITS UP TO MY DEALER.WELL MY DEALER DIDNT BUILD THE CAMPER,GOT THE RUN AROUND FOR THE 7TH TIME .NORTHWOOD IS JUNK TELL EVERY 1 TO BEWARE.MINE IS NOT SAFE TO HAUL.AND NOT PAID FOR YET UNREAL DONT KNOW WHAT TODO.
May-26-2015 05:15 PM
Mar-31-2014 07:41 AM
Mar-30-2014 07:00 PM
Mar-30-2014 06:41 PM
Feb-13-2014 08:01 PM
bka0721 wrote:You are assuming mounting the TC solid to the truck bed is better. There are many things to consider, with the overall framing at the top of the list.
Jfet is making his own camper. He has the long Flatbed build going.
It is good when one recognizes a weak area and makes the needed corrections. To bad the National Manufacturers cannot build something better.
b
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Feb-13-2014 05:02 PM
Reddog1 wrote:Jfet wrote:Reddog1 wrote:
I am kinda amused by some of the posts. Have you ever really looked at how your tie-down brackets are installed on your TC.
Yep, I have looked.
Our manufacturer used 1/4" welded steel angle tiedowns wrapped and welded directly to the steel frame.
And who was the manufacture?
Wayne
Feb-13-2014 03:54 PM
Feb-05-2014 06:36 PM
Yep, I have looked.
Toad: 91 Zuke
Feb-05-2014 04:37 PM
Feb-05-2014 12:15 PM
Grodyman wrote:
Hey anutami,
Let's see some pics when you get your camper! Did you get the rollover sofa or the dinette? I was seriously considering this model before I landed on the Lance 830 with rear tent. It has larger holding tanks and two propane tanks I believe.
Gman
Feb-05-2014 09:42 AM
Feb-05-2014 08:12 AM
Feb-05-2014 07:29 AM
Feb-05-2014 04:14 AM
BradW wrote:Mello Mike wrote:
So in this case a frame-mounted tie down on the rear probably would have saved this camper from going airborne.
Maybe. Or maybe the rear camper tie-down eyelet may have failed.
Regardless, I wasn’t there and I ain’t go no video evidence, but I don’t find it credible that a violent camper ejection like this was all cause by a crosswind while driving at only 25 mph. JMO.
Brad
