fixed my brakes
nayther
had really crappy brakes and have not been able to get it in for warranty. Wasn't sure if it was truck or trailer until I towed my son's trailer last month and all was good.
Pulled break away and wheels seemed to lock OK so figured it was somewhere from truck to trailer. Pulled the j box cover under the tongue and poked around, found the wire connector going the the brakes:
this is all that was captured in the crimp, 6 strands:
I wonder why I only read 3.5 volts at the magnet!
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
15 REPLIES 15
All_I_could_aff
Heat shrink tubing is my best friend
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
down_home
No crimps for me if I can get to it. Twist good Solder and heat shrink tubing liquid tape tape and make sure wires are not just hanging loose.
seaeagle2
They also make crimps that are different sizes on each side. ie Blue on one side and yellow on the other.
2014 F 250 Gasser
2019 Outdoors RV 21RD
"one life, don't blow it", Kona Brewing
"If people concentrated on the really important things in life there'd be a shortage of fishing poles" Doug Larson
nayther
hooked up to move it last night and brakes seem to work fine. Will pull it out for the weekend tomorrow and adjust the gain but already sleeping better.
DIRT BIKES RULE
mike-s
theoldwizard1 wrote:
Use a piece of scrap wire (or the fourth wire)and do the same for the remaining wires.
Much easier to just strip twice as much insulation from the last wire and then bend it in half to make it work.
nayther
Do a good 3 wire splice/tap is not easy to do. Here is my method, which is also what I do for a 4 wire splice/tap.
  • Start with butt splice that is one size LARGER than is required
  • Strip all wires
  • Twist together 2 from different circuits (in the picture above, the back and on blue)
  • Insert and crimp this into one end of the butt splice
  • Use a piece of scrap wire (or the fourth wire)and do the same for the remaining wires. Trim the scrap off and close to the splice as possible.
  • Heat shrink (either a separate piece or use shrinkable insulated butt splices) are a MUST !
I soldered and used shrink wrap, nothing better. Might redo all the connections next, very suspicious now.
DIRT BIKES RULE
theoldwizard1
  • Strip all wires
time2roll
If you have a DC clamp-on ammeter... check each wheel is getting about three amps when the controller is applied manually.
nayther
Old-Biscuit wrote:
Now you need to go to each wheel and check wire connections for brake Magnets.
Need to check ALL THE CONNECTIONS!
DIRT BIKES RULE
nayther
DIRT BIKES RULE
Lynnmor
I had a brake magnet that didn't have the wire stripped and was crimped on the insulation. This sure is quality stuff being produced.
Old-Biscuit
time2roll
I use these for that application:
https://www.waytekwire.com/products?pSearch=multiple%20sealed%20wire%20connector&psType=E
Perfectly waterproof sealed for all weather conditions.
Those crimp caps are for inside work.
mat60
Nice job finding this problem. Its funny all you can find when you get looking.
2018 Heartland Trailrunner 24 SLE... 1999 old style Chevy 2500 with 34k
