โSep-02-2018 05:15 PM
โSep-10-2018 06:03 PM
โSep-10-2018 05:15 PM
โSep-09-2018 09:19 AM
โSep-06-2018 09:25 AM
โSep-04-2018 08:26 AM
theoldwizard1 wrote:Much easier to just strip twice as much insulation from the last wire and then bend it in half to make it work.
Use a piece of scrap wire (or the fourth wire)and do the same for the remaining wires.
โSep-04-2018 06:58 AM
Do a good 3 wire splice/tap is not easy to do. Here is my method, which is also what I do for a 4 wire splice/tap.
- Start with butt splice that is one size LARGER than is required
- Strip all wires
- Twist together 2 from different circuits (in the picture above, the back and on blue)
- Insert and crimp this into one end of the butt splice
- Use a piece of scrap wire (or the fourth wire)and do the same for the remaining wires. Trim the scrap off and close to the splice as possible.
- Heat shrink (either a separate piece or use shrinkable insulated butt splices) are a MUST !
โSep-03-2018 11:56 AM
โSep-03-2018 09:53 AM
โSep-03-2018 09:49 AM
Old-Biscuit wrote:
Now you need to go to each wheel and check wire connections for brake Magnets.
โSep-03-2018 08:50 AM
โSep-03-2018 06:02 AM
โSep-02-2018 09:48 PM
โSep-02-2018 08:39 PM
โSep-02-2018 05:59 PM
