โOct-30-2013 05:08 AM
โNov-01-2013 10:37 AM
Old-Biscuit wrote:
Lower hitch.....
Raise pinbox....
Adjust springs in shackles......
Flip axles.......
Cut off shackles. Weld square tubes on to frame. Weld shackles back on.
That's about it for choices to adjust 5vr height
โNov-01-2013 06:59 AM
โNov-01-2013 06:14 AM
Dutch & Di wrote:
Thank you for the link and the info. It does sound like a good alignment bonus but I had forgotten that we don't have axles. We have IS suspension so this won't work for us.
Our brand new 2014 2 wheel drive Ram sits as high as a 4 wheel drive giving us only 5" of clearance at the bed of the truck which is not enough. Dutch is investigating the different bolt patterns on our Mor/Ryde IS which would allow us to raise it, but according to Mor/Ryde gain only 1". He is also investigating another way to gain more clearance by using steel tubing between the chassis and the IS. That should give us 2inches or more of clearance. This would be very extensive and expensive work.
Has anyone out there done anything other than these 2 options? If so, what did you do? We have a triple axle Carriage
We had to leave Montana to beat the snow & cold so until we can get this taken care of, we are making sure we are on as level ground as possible when we make a turn.
Any suggestions will be appreciated. Di
โNov-01-2013 05:17 AM
โNov-01-2013 04:29 AM
Dutch & Di wrote:
... but I had forgotten that we don't have axles. We have IS suspension so this won't work for us.
.... We have a triple axle Carriage
โOct-31-2013 04:04 AM
wandering1 wrote:
Put a lowering kit on your truck, don't screw up the center of gravity on your trailer and not have adequate steps by flipping your axles.
โOct-30-2013 08:58 PM
โOct-30-2013 07:54 PM
โOct-30-2013 07:03 PM
Dutch & Di wrote:
Did I miss something? I googled Correct Track but I didn't see anything about raising the 5th wheel. I'm asking because this is something we are definitely going to have to address. Could you or anyone provide a link that shows raising the trailer? Thanks DiBillB3857 wrote:
Since not having knowledge of the "Correct Tract" system, I did a Google search. Surprisingly, it took me to a surgical procedure. Trying a search for "Correct Track" took me to a Lippert Components site. Looks like a reasonable fix for several problems.
โOct-30-2013 06:54 PM
โOct-30-2013 05:45 PM
โOct-30-2013 04:54 PM
โOct-30-2013 04:40 PM
โOct-30-2013 11:49 AM
โOct-30-2013 07:35 AM
