Sep-29-2013 09:49 PM
Sep-30-2013 03:45 PM
Sep-30-2013 12:29 PM
Sep-30-2013 12:07 PM
Sep-30-2013 11:57 AM
MookieKat wrote:
How do you add the fans and where are they installed?
Sep-30-2013 10:54 AM
ken white wrote:NC Hauler wrote:
Gotcha...My 4 door fridge is in a slide, but again, there is an outside vent near the top and one in the bottom, (two vent's), with a very efficient fan blowing on the coils, when on...Again, have never had an issue was just curious. I know some have added a fan or two, mine already had the two vents and a very good fan.
X2...
Sep-30-2013 10:28 AM
720Deere wrote:
NCHauler, most people that experience cooling issues have their fridge located in a slide out. When located in a slide out, the top vent is on the side of the slide and does not allow heat to easily escape straight out of the top like a roof vent. Usually adding a fan or two above the coils helps fix this problem.
The biggest problem I have seen with them is like any other absorption fridge, they lack a fan inside to circulate air over the cooling coil. Adding a decent fan helped mine achieve the same temperatures on #7 as it did previously on #9.
Sep-30-2013 10:26 AM
Sep-30-2013 09:52 AM
Sep-30-2013 09:14 AM
jnharley wrote:
We have a 10 cf Norcold. It is plenty big enough for the 2 of us and does not seem to have the same problems that the 4 door ones have. We have a wireless thermostat that monitors the freezer and fridge separately and also one on our residential fridge. The temp swings are almost exactly the same. The residential freezer can maintain a lower temp than the Norcold. I generally see temps around 6 degrees with the Norcold freezer and 10 degrees lower with the residential one.
Sep-30-2013 08:35 AM
korbe wrote:
a lot of our fruits and vegetables don't need to be stored in the frig - high consumption rate.
Sep-30-2013 08:33 AM
Sep-30-2013 08:25 AM
Sep-30-2013 07:58 AM
