Merry, I also have a PW, but not the Pursuit. I think the following instructions may still work for you since it is a common problem for PW owners: Open the door to the compartment that has the battery "kill" switch in it (the red key). You should see two circuit breaker boxes in there too, a 40 amp and a 15 (or 20) amp. On the side of each box is a teeny tiny button that pops out when the circuit breaker is activated. You have to push the button in to reset the breaker and turn on the electricity again. Now, this button is very very small and may not be visible; you have to feel for it usually.
If the Pursuit doesn't have this set-up, I'm sorry. I suggest you try joining the PW Facebook group and/or Yahoo group since many more owners have experience to help you there.
Good luck!
Barbara, Florence, Rascal (bad chihuahua), and Annabelle (good girl turning bad)
Rainbow Bridge: Magoo (baddest chihuahua)
2007 Pleasure-Way Ford Excel TD: Miss Daisy
