V10 not perfoming like it should
Captain_Happy
I looking for shop to take my 2007 Ford V-10 to in the Las Vegas, NV area to get it diagnost to find why it's not running right. I use to own a 2000 Ford V-10, and this 2007 370+ HP engine is just doesn't have it. The tranny downshifts on the little's hill.
We where on a trip up to Oregon last month and for a few days I was running up medium hills like I was on flat land, and had to back off to keep from running into the person I was following. On the return trip it's right back to the way it's running now. Any help?
13 REPLIES 13
Antony
FYI, the threshold for the MIL to come on because of a misfire is insanely high on Ford mod motors. The technician needs to know how to navigate the Mode 6 data to find the misfire rates for each cylinder. The last time I changed a COP on our van, all cylinders' misfire count was 0 except for cyl #7 which had a count of over 8000.....still no MIL....just a jittering pile of torqueless **** when loaded.
Anthony
Cecilt
Not sure if the MH exhaust is the same as the trucks but I have a 2009 V-10 and my performance had progressively gotten worse over the last 2 years. Lack of power, high RPM's to run grades that before I could drive without the high RPM's and lots of shifting. Turned out the catalytic converters were bad. Just got the truck back last week and it is like a brand new vehicle. Replaced under warranty as the Cats had an 11 year 120k mile warranty. Might want to check this.
spud1957
Captain_Happy wrote:
If this had been all the easy stuff to fix, it would have been fixed by now. Thanks anyway guys.
It's going in the shop on Wednesday.
Interesting response. Don't like the answers? Don't ask the question.:R
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
Captain_Happy
Belgique
bettye wrote:
We have an '01 Ford V10 and recently experienced the same issue. Turns out it was the mass air flow sensor.
In my 08 it was a bad front O2 Sensor and cleaning the mass sensor while they were there. My mileage had cut in half and this restored it to normal.
Hickory, NC
2007 Fleetwood Discovery 40X
bettye
Betty & Jim
2004 Allegro Bay 34XB
jplante4
Did you try any on the suggestions made in the thread you started about this 2 weeks ago?
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Goldencrazy
Chum lee wrote:
Can you be more specific? Not "running right" is a little too vague for any meaningful online diagnosis. Is your "service engine soon/check engine" light on? Throwing parts at a problem you don't understand is about as effective as having a "mechanic" at Jiffy Lube open the cowling.
Chum lee
I need a like button.
Chum_lee
Chum lee
rockylarson
Ethanol Free Gas Try a tankfull or two from these locations and see if it improves. It is the only way I can keep my check engine light from coming on. Good Luck.
BTW, there are IPhone and Android apps also.
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
carringb
What they all said.... Check the basics first... Air and fuel filters, mouse nest in the intake... Brakes aren't dragging (feel for a hot wheel).... If you can't find anything obvious, it'll probably need to be hooked up to a diagnostics terminal.
Also make sure the proper oil (5w20 or 5W30) was used at the last oil change. Heavier oils can affect cam phaser performance which changes valve timing.
2014 ORV really big trailer
2015 Ford Focus ST
MountainAir05
Then check the COPs, (Coil on Plug) Air filter
fourmat
replace fuel filter first
2009 Challenger
