30 Amp Question
biggjc
I have a question that will probably seem idiotic, but here goes. I am booked at a campsite that offers 50 amp service. My motorhome has a 30 amp plug-in. Can I
use a 50 amp to 30 amp pigtail type device without worry? I see them for sale for approx $20 , but want to make sure that I am Ok doing this. Many Thanks.
18 REPLIES 18
Cummins12V98
Spend the money and buy the YELLOW CAMCO with "D" handles for ease of separation and long term durability.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
IndyCamp
2112 wrote:
I always use my 50A adaptor when I can. Many times the 30A pedestal receptacles are in poor shape while the 50A looks new.
Me too.
Any time I am at a site that has both, I use my adapter and plug into the 50A.
2018 Grand Design Reflection 315RLTS
2014 RAM 2500 6.4L HEMI
Hank_MI
Veebyes wrote:
williamp321 wrote:
WalMart has the pig tails.
Would they be in the meat freezer section?:h
Pickled, in a jar on the shelve.
Veebyes
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
wa8yxm
IN addition most 50 amp boxes contain both 30 and 20 amp outlets in addition to the 50.
Where I'm parked you can use both 30 and 20 amp all day no tribble. but if you try to use the 50 and one other ... You can trip your site breaker back at the park servie panel.. Each site has its very own feed all the way back to the main.
(Actually this is a very good way to wire an RV park).
rockhillmanor
imgoin4it wrote:
Only once in nearly 15 years of RVing have I encountered an RV park that had only 50amp service and no 30amp outlet available. That was in Alaska near fairbanks.
There are a lot of CG's thru out the US now that have pull thru sites for the big coaches that only have a 50 amp shore station.
If you don't ask for those sites one would not know that they are only 50 amp.
If park is full and those sites are open they will park you in those sites no matter what type of coach you have. I tow and always 'ask' for those sites and yup most of the time they only have 50 amp. :C
RoyB
Always nice to have the adapter on hand to use. Most everyone uses the 30AMPS receptacles and alot of them don't look very good connection wise...
The 50AMP Receptacle next to is usually as clean as can be...
I got mine from WALMART... Looks like this...
This is a diagram showing how it works... Notice that it only taps into one HOT side of the 50AMP Service for you to use... Although you have 50AMP service available to use your trailer 30AMP breaker will keep you from using more than than 30AMPs otherwise the trailer 30AMP breaker will trip.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Us_out_West
Not once....never been anywhere where it was just 50amp at the pedestal.
Just 30amp or less...yes.
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
imgoin4it
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
CavemanCharlie
Yes,
Often the 50 amp receptacle will have seen less use and be in better shape.
A surge protector is cheap insurance no matter where you plug in.
JoeTampa
To simplify, the major difference between 30a and 50a is the amount of current that each can provide to your RV. If your RV has 30A service, it will/shouldn't draw more than 30A, and can be plugged into the 30A without fear of tripping the breaker by drawing too much current.
50A service will (should!) have thicker wiring to handle larger current loads, and so should the wiring going to a 50A trailer. Therefore, you can plug into 50A service (with the appropriate plug adapter) since you won't be needing/using the increased current capacity anyway.
The same - it should be clear by now - is not necessarily the case going the other way; i.e. a 50A RV plugging into 30A service. The 50A RV *could* try to draw more than 30A, which should cause the breaker to trip. My trailer - with 50A service - doesn't draw more than 20A with the AC on and the compressor running, so I can use 30A service if needed. That's not true for many 50A rigs, however.
2006 Keystone Cougar 243RKS (First trailer)
2016 Jayco Jay Flight 32BHDS (Traded in)
2016 Jayco Jay Flight 33RBTS (Current)
2006 Chevy Silverado 2500HD 4WD 6.6L Duramax Diesel (LBZ)
Blue Ox Swaypro 1500 WDH
Prodigy P2 BC
Amateur Call AB2M
2112
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
2oldman
biggjc wrote:
I was pretty sure I knew the answer, but didn't want to be that guy who fried all of his electronics. Thanks again to all!
Amps don't fry, volts do, which is why a good surge guard is recommended by many.
biggjc
Thanks for the quick reply's! I was pretty sure I knew the answer, but didn't want to be that guy who fried all of his electronics. Thanks again to all!
