โMar-17-2017 04:16 PM
โMar-22-2017 04:03 PM
Aridon wrote:CA Traveler wrote:
Yes you can take the receiver with you as long as it's not a Genie Client which is NOT a receiver. However once you travel several hundred miles you will leave the local spot beam and no longer get the national channels. If you call and get the local channels for the rig then the home receiver will no longer get its local channels.
If someone were to fall under this one option is to "move" to NYC or LA area. Pick a fake address, apartment or condo and add a number or letter to it. This will net you the CONUS locals and you'd have access to at least all your network programming, minus your local news naturally as that would be NYC.
โMar-20-2017 06:18 PM
โMar-19-2017 08:36 PM
โMar-19-2017 06:55 PM
โMar-19-2017 06:12 PM
EsoxLucius wrote:Rbertalotto wrote:I've been fulltiming for three years and LTE networks, WiFi and OTA are not reliable for consistent television viewing.
I predict that within month, the sight of satellite dishes on RVs will go the way of the dinosaur. I can not see the need, expense and deployment making any sense as the cost for unlimited services continue to crash and the network gets better and better....
โMar-19-2017 05:51 PM
โMar-19-2017 05:45 PM
โMar-19-2017 04:27 PM
โMar-19-2017 08:20 AM
โMar-19-2017 01:58 AM
enblethen wrote:
You must have two cards that are active through DirectTV.
โMar-18-2017 10:13 AM
โMar-18-2017 04:08 AM
โMar-17-2017 11:56 PM
Aridon wrote:THIS
Sure, so long as the receiver isn't dependent on another box to work such as the genie clients. If you have something like a Genie at home and a hr24 on the road they will work so long as they are attached to a dish pointed at the right bird
โMar-17-2017 07:02 PM
