โApr-09-2015 11:08 AM
โApr-23-2015 02:23 PM
โApr-23-2015 02:14 PM
โApr-23-2015 01:33 PM
gbopp wrote:
I started using air for the lines and antifreeze for the traps a few years ago.
Our Pennsylvania winters have not caused any problems.
It works for me!
โApr-23-2015 01:04 PM
โApr-23-2015 12:21 PM
mlts22 wrote:And your lines are sanitized as well!
I do a third option: Cheap vodka. The ethanol will lower the freezing point of the water enough so that a 20 degree day in Texas won't result in cracked pipes. Plus, I don't have to worry about bad taste in the lines when I dewinterize and sanitize in the spring.
โApr-23-2015 09:58 AM
โApr-13-2015 05:26 AM
LarryJM wrote:
Only using air can be a hit or miss proposition and can depend a lot on how an RV is plumbed. Also you have to use it in your traps anyway. Air doesn't winterize the FW pump and just running it dry may or may not work depending again on it's specific location and how the lines are plumbed into it. I also think you will find the only universally accepted and recommended method of winterizing is to use the pink stuff and not just rely on using air so I disagree with you belief that using it is somehow more prevelant here on RV.NET than other sources of information. I would bet if you take your RV into almost any RV dealer and ask to have it winterized they will include using the pink stuff and will not just rely on blowing out the lines with air.
Larry
โApr-12-2015 08:25 PM
โApr-11-2015 06:37 PM
LarryJM wrote:JaxDad wrote:
The irrigation industry has been doing it for nearly a century now, you don't see them digging up golf courses and other expanses of fine turf looking for burst lines because it doesn't happen.
ROTFLMAO, you're not seriously trying to say the plumbing design (i.e line sizes, low point drain points that never move or change orientation) is equilivant to our 1/2" uniformed sized FW system designed and thrown together by the lowest bidder.
GIVE ME A BREAK:R Just this non germane attempt at making an apple inot an orange shows me a very HUGE DISCONNECT in understanding the issues here, but I think the more astute readers have gotten the point and will realize the serious potential limitations in using the air only method so I'M DONE:W
Larry
โApr-11-2015 05:23 PM
JohnG4706 wrote:mowermech wrote:
"...they just have their friendly contractor come in, connect his air compressor to the sprinkler lines, and BLOW THEM DRY!
But then, I guess plastic sprinkler lines are nothing like an RV water system.
The big difference is that a contractor's compressor, used for jack hammers, etc., are high volume and low pressure. The compressors used for nail guns are generally high pressure and low volume. Some only have 1.5 gal, pancake type, capacity to maybe 20 gal size.
Yes, you can regulate the pressure in the high pressure low volume compressors to 50 psi but understand you have low volume to blow out your lines and will have to repeat the blowing out several times for best results. I did this on my inground PVC sprinkler system in northern Illinois. PVC isn't as forgiving as polypipe.
โApr-11-2015 04:27 PM
โApr-11-2015 04:07 PM
โApr-11-2015 03:36 PM
โApr-11-2015 03:17 PM
