Removing a 120 volt receptacle and cover plate
NanciL
How do I get a 120 volt receptacle and plate out of the wall in my trailer? There are no screws showing.
I am guessing I have to pry the cover plate off, but figured I would ask here first.
Jack L
Jack & Nanci
5 REPLIES 5
pianotuna
Nomad III
Nomad III
If possible replace with a "real" box and outlet.
Regards, Don
SoundGuy
It's just a garden variety Speed Box Duplex Receptacle ... just carefully pry off the cover which is secured in place with a couple of plastic tabs to gain access to the receptacle itself.
2012 Silverado 1500 Crew Cab
enblethen
some have small points on the back of the cover plate that snap into the receptacle. You would need to pry the cover off.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Lynnmor
Pry off the face plate and then turn the screws on opposite corners. It may take many turns to remove the outlet.
Mfan
Probably 1 piece. Work 1 side at a time
