Sewer Hookup @ Home?
superrayzor
I am parking right next to my garage, so power and water are easy. I am going to add 30AMP service myself, and water is already there.
Has anybody ever added a sewer hookup at their house? How easy is it, can I just route to the cleanout or tap anywhere into the sewer line? I don't want to use the flexible hose - I want to connect a real pipe to the motorhome and just pull the levers when it gets to 2/3 full.
Any thoughts or insight on the sewer would be appreciated.
30 REPLIES 30
ddndoug
OK... This may be a silly question, but why is everyone insistent on a macerator? If you're dumping into a public sewer system, you're dumping the same thing from your tanks that you would if you're flushing your toilet.
Doug
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
Bucky_Badger
Dutch_12078 wrote:
When we submitted the drawing for a new septic system for our vacation cottage to the building inspector 10 years ago, he was the one that change the "RV dump station" label to "4 inch cleanout". It probably helped that he's also an RV'er... 😉
Lucky You!!!LOL
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
ktmrfs
In our area ALL houses are required to have a cleanout on the front of the house. I just use it with a macerator pump. works great.
2011 Keystone Outback 295RE
RollandB
I agree with the comments on calling it clean out. Anything else may have your jurisdiction looking with more scrutiny and probable a permit fee.
Two years ago we had the sewer line replaced t our home. The plumber put in 3 clean outs with sweeping el tees do the snake could go either direction if needed. One is opinion the parking strip near where we park the RV when it's home. The city even put a cast iron cover marked sewer on it. If the place where we store it didn't have a dump station I would have a macerator. Still may buy one some day
2013 Yukon
2021 Coachmen Spirit 1943RB
korbe
I would first locate the existing line to make sure I have at least -1 to -2-percent slope from my rig. I would then determine the existing sewer pipe material and put in the proper "y" connection. I would trench at the needed slope and put in a threaded cap just below the surface (with box & lid). I would design that pipe run & connection (with ABS sewer pipe) so I could support the above ground pipe and also be able to disconnect(unscrew) it at the box and store away when not needed.
And if you feel the need to get a permit or have a plumber do it, that's fine too.
riven1950
My house is on pilings. There is a code required clean out where the pipe goes into the ground. I just unscrew the clean out and screw in my drain adapter. I don't do permanent. Neighbors or Town would have something to say.
Sport45
Fire Instructor wrote:
If you are on municipal sewers, the "impact" of a 50-gallon flush will be negligible. Not so on an individual septic system. A septic system will take the flows from a macerator, as its really no more than the input flow from a washing machine...
Thank you.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
rockhillmanor
mlts22 wrote:
There are two general ways to do this:
1: Have a plumber
add a "clean-out" near your rig. Semantics are critical here... you don't want to use the words, "dump station", since you might run afoul of a lot of regulations.
However, a clean-out where your dump hose adapter screws onto is perfectly OK.
2: Use a macerator pump. Done right, it isn't that much of a hassle, it allows you to pump uphill.
X2
I've yet to hear of any place that will 'allow' you to hook up a MH to the existing sewer lines. SOOOOO be wary of what you say to a plumber if you go the route of one putting in a 'clean out' for you. Do not tell them of your intentions for the clean out. Many a license plumbers will NOT do what is against code.
And sadly your worst enemy doing this is going to be your neighbors. If you have the choice place your MH out of the line of sight of any of the neighbors. Because once they see a sewer line coming out of it trust me one of them will call you in.
Adding a clean out especially with plastic pipe is very easy.
SoundGuy
1: Have a plumber add a "clean-out" near your rig. Semantics are critical here... you don't want to use the words, "dump station", since you might run afoul of a lot of regulations. However, a clean-out where your dump hose adapter screws onto is perfectly OK.
Here in Canada a so-called "sewer clean-out" located somewhere on one's property is unusual, particularly in newer subdivisions, and I certainly don't have one. Even if I did I wouldn't choose to passively dump the contents of the trailer's black water tank, instead invested in a FloJet Waste Macerator Pump and installed a T to the main sewer stack in the house. I've been using this system for 10 yrs now and it's faultless, also use the macerator when camping ... a series of 7 pics starts here for anyone interested.
2012 Silverado 1500 Crew Cab
Fire_Instructor
Fire Instructor
2022 Coachmen Leprechaun 319MB
wbwood
Sport45 wrote:
Are you hooked to a city sewer or a home septic system? This may make a difference on how you set up and use the system.
A home septic system might not appreciate a 50-gallon flush...
First of all, it depends on the size of his tank as to whether it would be 50 gallons. With that said, that makes no sense. Home bath tubs range in sizes of 40-120 gallons. Long showers could generate that amount or more. A properly working septic system should be able to handle it.
And I've asked a septic company about using our cleanout to dump and he said it would be fine for a single RV use, just not an multiple rv use daily.
Brian
2013 Thor Chateau 31L
Sport45
old_guy
easy to do really just need the right slope for drainage. the clean out can be added and then cut it down so you can use it
mlts22
