Spare Fuel
wkrp
Is it OK/Safe to carry some spare fuel in the your truck?
We will be on a stretch of highway that has "some fuel stops" but from the looks of them on Google Earth, none that are easy accessed by a 4dr. truck with a 30" TT.
If I do carry extra fuel it would be in metal, OSHA approved cans.
WKRP
25 REPLIES 25
EPenney
There is a lake up in the High Sierra we tow our 5er to, and the nearest diesel is a 45 minute drive back down the mountain. I always pack a 5-gallon can of diesel when we go up there.
A view like this makes taking fuel along worthwhile......
'07 Chevy 2500HD Silverado "Classic" CC D/A 4x4
'07 Komfort Trailblazer T252FS fifth wheel
Reese Signature 18K Slider and other stuff.....some useful.....some not
CincyGus
wkrp wrote:
I didn't think there would be but just wanted to run it past more experienced travelers.
There are some fuel stops between Charleston, WV and Lexington, KY on I64 but they don't look very user friendly to a large truck (gasser) with a 30"TT.
If anyone knows of a good one please let me know.
WKRP
I just make sure to watch for the highway gas signs that have the little emblem for each of the stores on them. When I see one with multiple and can see a few of them right around the exit, I know my chances of having at least one of them with a large enough parking lot and room for me to get in increases. As you approach, do as I do and look for the easiest pull in that will leave plenty of room to exit. The main two considerations are the amount of space after the last pump before you have to start turning and how much room you have to swing wide in prep for that turn. I generally like the isles on the ends for that reason.
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
okeehandyman
Having trouble with the time to pour fuel from containers sounds like a venting issue with those goofy new style jugs.
Remedy: look for UTUBE video showing venting solution using tire valve stem installed in upper part of jug handle area. It only involves one 1/2 inch hole and a valve stem with the core removed. Tried it and it works great!!
BBdawg
BBdawg wrote:
Bob Vaughn wrote:
My problem with using the 5 gallon gas can's is getting the pipe into the gas tank fill hole then holding the gas can long enough to empty the can. I need to find a hose extension that I could put on can then set that on my roll top case and just let it drain by itself.....
You might look at something like this -
http://www.chainsawsdirect.com/Scepter-6792/p798.html?utm_source=nextag&utm_medium=paid+portals
I purchased a similar tank at a big box store for far less, but there is an answer to your wishes..
Ok, here is the one I actually had. < $50
http://www.northerntool.com/shop/tools/product_200422211_200422211?cm_mmc=Google-pla-_-Fuel%20Transfer%20%2B%20Lubrication-_-Fuel%20Nozzles-_-169476&ci_src=17588969&ci_sku=169476&gclid=CP3n9vaetbcCFWIV7AodSQoARw
Made my life a lot easier when trying to fill lawn equipment.
BBdawg
Bob_Vaughn
aruba5er
When I got my fiver I hurt the side of it pulling into a gas station trying to manueuever around the concrete safety things. From then on I carried 4- 5 gal cans of diesel and 1 5 gal can of gas. Never again will I attempt to go into a regular station. The extra cans saved my bacon more than once. I might add that we never take the major highways so that eliminates the truck stops.
mlts22
I always keep a couple 5 gallon cans of gas handy in my truck's bed, secured with a ratchet strap through the handle so they don't bounce around or topple over. This fuel is mainly for the generator, but I've saved friends letting them use the gas for an emergency top-off.
The most elegant setup are Rotopax installs. These are low-profile, 2-4 gallon containers as mentioned above. My next RV setup will be a motorhome towing a small cargo trailer (4-5 feet width) for my boondocking expeditions. With this, I can mount Rotopax containers on the front of the trailer which will still allow for extended fuel range, but with the use of locking T-handles, the containers will tend to not disappear.
rhagfo
Old-Biscuit wrote:
It's only 175 miles between the two places.
Fill up prior to leaving...then after setting up go fill up again.
I only use regular gas stations (with diesel) vs truck stops.
If I can get rig into/out of CG's I can do so at gas stations.
Even if I have to back out :B
X2 I just completed a 200 mile loop to the coast, didn't even think about fuel.
silvercorvette
Trust me on this when I drove up to NY from SC there were a few stations that were difficult to get into with my long bed crew cab. There are some areas in the NY city NJ area that are probably almost impossible for the fuel trucks to get into during the day time. I am guessing they have to deliver at night when there aren't any cars blocking off the station. Once I get out of the NY city area and into Suffolk County LI it is easier to find a station they are going to cost you fifty cents to a dollar more per gallon
2014 4 WD Silverado 403 CI diesel long bed dually, B&W hitch with 95 Gallon Auxiliary Fuel Tank, pulling a 33 foot Holiday Rambler Alumascape suite, Winegard SK-3005 TRAV'LER slimline dish, Splendide 2100 XC washer dryer, TST Tire Pressure monitor system.
wkrp
Old Biscuit:
I am actually coming from Parkersburg, WV which adds on another 80 miles. 255mi. total.
Old-Biscuit
wkrp
Tondinwv
I looked youur suggestions on Google Earth. Look like a Go Mart that is OK and a Texaco just past it that is easily accessible. They are on Carol Malone Blvd.
Thanks for the help. I like to do this before my trip instead of during. Makes the trip much more enjoyable.
WKRP
silvercorvette
I have a spare 95 gallon diesel tank in addition to my 36 gallon truck tank. I also keep about 2 to 5 gallons of gasoline in my truck bed for my generators. As long as you do not store the gas inside your RV or your truck you should be OK. I honestly do not think that keeping less than 15 or 20 gallons will not be much help, 5 gallons will only give you about 50 miles. If it were I, I would want at least 100 miles of extra fuel, 150 to 200 miles is even better.
