towing with v6 Ram
richy2
I currently tow a 29' 5300lb TT with my 2014 Ram v6. It tows great and I average 12 to 13 mpg. I am looking at a 33 foot TT that weighs 6100 lbs. The Ram has a maximum towing capacity of 7500 lbs. Question: Would I have enough margin to tow this trailer comfortably?
Thanks
12 REPLIES 12
jerem0621
fireman41 wrote:
Low grear and 4 way flashers on the big hills. Just get used to the slow lane. If not over any weights go for it. Just don't expect to be king of the hills.
And when getting onto the interstates plan your merging carefully cause you won't get up to speed as fast.
So inaccurate...
It's a 305 HP Pentastar V6... Not a 2.8 S10 v6 with 115 hp..it's not a Hemi but it's not a weakling by any stretch.
If it's in the slow lane crawling around its because the driver is slow... The truck is powerful and will pull its rating with zero problem.
Op, let it rev and it will be fine.
Thanks,
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
bluepost
SAE J2807 test protocols include:
Cooling capability on a long highway upgrade
Launch and acceleration on a level road
Launch and acceleration on a 12-percent grade
Handling performance in terms of understeer and trailer sway
Braking performance in terms of stopping distance and parking brake hold on a grade
Structural performance for the vehicle, the hitch, and hitch receiver
Furthermore, SAE J2807 assumes the following when calculating trailer weight ratings:
Light-duty truck ratings assume inclusion of any options with higher than 33-percent market penetration
The driver and the front passenger each weigh 150 pounds
The vehicle is equipped with up to 70 lbs. of hitch equipment
For conventional towing, 10 percent of the trailer weight is on the tongue
bluepost
The 2015 Rams meet the J2807 towing standards. That includes 2 people in the truck, climbing the Davis dam road in 100+ temps maintaining 40mph. You can count on the tow ratings now. The 2015 is about the same rating as the 2014. You will be fine.
mileshuff
I would assume that 7500lb tow limit includes only the driver, no luggage and a tank of fuel. Look up your trucks payload and GVWR. Probably will exceed one or both since a 6,100lb dry trailer will be over 7,000 loaded.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
fireman41
ib516
It will likely handle very similar to what you have now. It also won't be "unsafe" IMO, since the RAM 1500 is rated to tow over 10,000# in certain configurations.
Where you will notice it is in the performance and power. Maybe even engine cooling ability.
Whether that is acceptable performance to you is your decision. It wouldn't be for me, but everyone's definition of acceptable towing performance is different.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
TXiceman
Personally, I would never pull the smaller trailer with the v-6 you have.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
2012Coleman
Have you considered payload? Why don't you post a picture of the door sticker?
2018 RAM 3500 Big Horn CTD
ScottG
I think it will do it OK but leave you wanting for more truck.
APT
I would not be pleased with your current combo, so any more weight I would say no. But since you know how the current combo drives, adding 800-1000 pounds will probably not be very noticeable to the experience.
2017 Subaru Outback 3.6R
Old-Biscuit
Depends.....
Are those weights loaded or unloaded? Gross max or dry?
If loaded or Gross Max......OK
IF unloaded or dry.......NO
That mfg. MAX Tow Rating of 7500# is a magical number derived with a base model 150# driver and 20# cargo.
Nobody fits into that in real world.
GO weigh truck camp ready.......you, fuel, passengers, stuff in cab and stuff in bed.
Subtract that weight from trucks GVWR......that is actual payload (amount of weight you can add to truck)
Also look at what rear axle weight is and rear tire load capacity vs RAWR.
How much room to you have before reaching those numbers?
ChooChooMan74
In my honest opinion, I think you will be pushing the V6. A 6100lb trailer will probably weigh close to 7500 fully loaded, and with that you're pushing 800+ lbs of tongue. I think you will need more truck. I wouldn't tow anything that big with a 1500 Ram. Then again, others will say that they wouldn't tow what I tow with my little tractor.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
