Aug-18-2016 01:54 PM
Aug-24-2016 01:52 PM
rhagfo wrote:lawnspecialties wrote:Old-Biscuit wrote:
2010 F250 GVWR is 10,000#
Scaled weight.....11,060 (1,060# over GVWR)
GCWR.....23,000# (scaled 21,400)...so under by 1,600#
FAWR......6000 (scaled 5200).......so under by 800#
RAWR......6100 (scaled 5860).......so under by 240#
What is Load rating on rear tires?
Otherwise......
Under on axle ratings so I stamp it good to go (provided tires are NOT over!)
Exactly. Check those tires and roll on.
X3
Many would say not enough truck, then turn around an suggest at least a F350 SRW. :h
While escenally the same as the F350 SRW, the main difference is the tax and registering 10,000# class 2 limit.
Aug-24-2016 01:26 PM
4Kellys wrote:
Why would you be ok with being 1000 over your GVWR, I certainly wouldn't be!
Aug-22-2016 04:14 PM
Aug-22-2016 06:43 AM
SoCalDesertRider wrote:
All the weights are under the ratings, except the GVWR of the truck.
We know that both F250's and F350SRW's use the same axles and brakes and have the same braking ability.
The F250's GVWR is de-rated on paper to 10,000 lbs for registration reasons, whereas the F350SRW's max GVWR is 11,500 lbs.
So far as ability to stop the weight the truck is carrying, the F250 is good up to the max GVWR of the F350SRW.
So, this combination is A-OK, in my opinion.
Aug-22-2016 05:22 AM
Aug-21-2016 10:26 PM
Aug-19-2016 06:29 AM
Otherwise......
Aug-19-2016 05:25 AM
Otherwise......
Aug-19-2016 05:09 AM
Aug-18-2016 06:18 PM
Aug-18-2016 03:24 PM
Aug-18-2016 03:23 PM
JohnG3 wrote:
Have a 2010 Ford F250 crew cab 4x4 super duty diesel. Ford data shows 15300 pounds maximum towing weight. We tow a 2008 Montana 3485SA fifth wheel trailer. The shipping weight listed in the trailer is 12,000 lbs. The GVWR is 15250. We stopped at a CAT Scales on the way home from a trip a couple days ago to weigh the rigs. CAT scales weight each axle at the same time.
The scale printout is:
Steering axle: 5200 lbs.
Drive axle: 5860 lbs.
Trailer axles: 10340 lbs.
Total: 21400 lbs.
What's the opinion of the weight experts? The trailer was loaded with the usual stuff for a trip. The only variable is the food in the refrigerator.
Aug-18-2016 03:19 PM
Aug-18-2016 02:45 PM
