Yeah it's a tad cool here....
So here I am in Calgary Alberta, doing my best to work max hours and
build stuff.....
Brilliant Bob brings the TT and figures, yeah, I'll save big time on motels and all that.
Well, the weather has other ideas and really, it is a bit on the chilly side here.
I'm in about ten bottles of propane at 35 bucks a pop. But I'm warm anyhow...
Except last night where it was minus 32C and my propane decides to sleep instead of flow, because I wasn't smart enough to listen to Don tell me to put a heating pad on the bottles, but I got through the lack of flow bringing the temperature down in the 50's in here at 3;22 AM when I woke up and decided that yep! It's too cold in here!
Wander out in my undies at said such time and switch the bottles to the full one and yeah it made a difference, got a little flow at minus 32C and got a little heat in this thing.
Furnace managed to catch up in a couple hours and warm the place up.
Meanwhile Bob gets no sleep cuz he thinks of the pipes freezing up with the furnace in relax mode.
So I got up at o dark thirty to get out and at 'em. Gads no, I want to sleep.
but it was warmer than the 54 degrees I remember at 3:22 AM.
TT warmed up a bit as I fed the furnace with a full bottle instead of the who knows how low it is bottle.
7AM, alarm goes off. Hey Bob, get up and go to work!! I reply something I can't print here....
Finally I drag my sorry butt out of bed and look at the thermometer. Minus 32. Oh awesome!
Screw that, fall back into bed. Yeah maybe later.
Can't sleep now, gotta go to work, it's getting warm in here now anyhow, So I get up and out the door.
Minus 32C. Gads man am I out of my mind?
evidently, yes.
Whats wrong with this picture??
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
29 REPLIES 29
Golden_HVAC
Bob,
Considering that you are plugged into the HOST electricity, I would be running a couple of 120 volt heaters, electric blanket, and other heaters.
Like one on 800 watts near the fresh water tank and pump. It will at least keep the fresh water tank over 55F. That will lead to warmer showers.
800 watt heater (normal one on low heat setting) near where your water lines froze, such as under the kitchen sink.
Electric blankets are only about 35 - 45 watts.
You probably will need to run one 120 volt cord for each pair of heaters on low heat.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
pianotuna
Nomad III
Nomad III
Hi Bob,
You may want to check out my thread on heating 100% electrically.
heating electrically a "back yard" report
I'm glad it is warming up for you. Heading for -31 here tonight.
Regards, Don
colliehauler wrote:
I would have the local propane company drop off 100# cylinder and not mess with those small tanks. It would be less cost as well.
I can't do the 100 pound tank thing.
I move around too much.
ScottnSherrie wrote:
Is that the same TT you re-roofed way back when? It was in the 70s F here Friday but more like normal today with temps in the 40s F.
No not the same one I rebuilt way back when. That one still sits in my driveway unfinished.
colliehauler
TYSPapa
Good thing you were'nt 2 hours east of Calgary yesterday morning where it was -46 with a wind chill of -54. That was cool and not in a good way
1998 Dodge 1ton DRW 4x4,cummins of course:D
1998 Cardinal 28rks
ScottnSherrie
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel
complete roof rebuild
daughter 19, son 16
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
Steeljag
It was a cool on last night MT......lol
It's been in the low 80s here and sunny, and even with solar, the pool temp has dipped to 81 degrees. Having to put on sun block this time of year is outrages!
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
MTPockets1
I feel for you up North. That's why we spend winter in FL past 9 yrs. Got downtown 66 F last night.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
JaxDad
First thing you should do IMHO is get an adapter and a 100 pound cylinder or three!
Those little cylinders don't work well, not enough surface area. You need a bigger cylinder, and lean it over some so you have way more surface area.
BTW, those little thermostatic heat strips designed to keep pipes from freezing work way better than a heating pad. Get a long one and wrap it around and around, then put something around the tank to insulate it and keep the warmth in. Be sure to put the heat strip low, it's the liquid you want warmed.
Deb_and_Ed_M
Opie431 wrote:
Everytime it gets cold here I think of you. We have not hit zero yet this year.
Give it time..... ๐Ÿ˜‰
Ed, Deb, and 2 dogs
Looking for a small Class C!
bradyk
Well Bob it is looking better. It is only -13 here in cowtown with a minus 20 windchill right now and going up to a balmy miuns 7 tomorrow. Good time to tweak your tanks.
2001 Chevrolet 2500hd Silverado LT 4x4 6.0L/4.10
2005 KZ Outdoorsmen 2605PF
Equal-i-zer 10K WDH
Champion 4000W Generator
Champion 2000W Generator x 2
Ken & Sandra
Yugi Dog, Jet Dog
DutchmenSport
It's cold in Indiana also ... so much for "global warming!!!" I wouldn't mind a little "warm" right now myself!
Opie431
Jim_Shoe
Nothing wrong with the picture. Only thing wrong is that you're in it. (You're the one shivering).
Retired and visiting as much of this beautiful country as I can.
