Grey water tank sludge
RTrider
Helping a friend with her grey water tank issues.
2009 36 ft. Motorcoach
The tank drains very slowly. About 4 months ago we drained the tank as best we could and then took apart the slide valve and connecting piping to the tank, leaving the tank outlet open. Sludge came out and because we were in a campground we could not let too much drain out as other units were next door. Put things back together and filled the tank and did some direct drains and all improved quite a bit.
4 months later, now back in the same situation. This time she is in an area she can dump the grey water tank onto the ground (at a farm). T
Two questions:
1) Any suggestions on how to flush the tank other than a hose directly into the tank through the exposed outlet when we take the piping apart. I am a little shy of using a pressure washer into the tank.
2) How can she prevent the sludge build up. She lives the coach full time and does not put anything but dish water and shower water into the grey tank. She does not have a dishwasher or clothes washer in the coach.
Any suggestions will be well received.
2011 Jayco Eagle Super Lite 298RLS (Sold)
2010 Chevy Silverado 3500HD Duramax Diesel LB/SRW (sold)
Equalizer Hitch, 1200 lb bars (Sold)
2010 Honda NT700A.
Rampage winch loader for bike in back of TV (Sold)
Some Pictures
12 REPLIES 12
Katdaddy
Try adding a cup of liquid dishwasher detergent and a gallon of hot water. Ride around for awhile and dump. Repeat as needed.
Little by little, one travels far - J.R.R. Tolkien
There ain't no surer way to find out whether you like people or hate them than to travel with them. - Mark Twain
docj
2oldman wrote:
Sounds like the tank needs a thorough cleaning.. but I don't know how that's done.
There is a national franchise operation called All Pro Water Flow that cleans both gray and black tanks with a pressure washer and specially designed small nozzles. We had ours down several years ago when we were experiencing what the OP has reported in this thread. It fixed us up, although we do need to have it done again.
Those of us who full-time in our RVs and have washer/dryers really can't keep the gray tank valve closed all the time unless we wish to risk washing machine overflow accidents. I don't mind having the tanks cleaned every couple of years as the price I pay for this convenience.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
gperky
Use some ingenuity to find a way to keep dirty dishwater out of the gray water tank. It's the grease and solids that cause the problems. We pre-wash in a separate pan before the final dish rinse, and then dump the pan in the toilet. Our black water tank gets a regular pressure wash, so it never has any problems.
rockhillmanor
2oldman wrote:
John Wayne wrote:
I'm betting she leaves the gray tank valve open whens she's parked..
Good point, pilgrim.
X3
The only way the gray tank can get sludge like that is if the valve is left open all the time. The grease and food stuffs just sit on the bottom and rot. Holding tanks need water in them for them to work properly.
Many that stay in their RV do it all the time. And many RV'ers.
Get some pinesol and pour a couple of quarts into the tank and fill with water, dump and repeat as necessary,"while you are hooked up to the sewer connction." That should clean it out and then "leave that valve closed" until full and then dump.
Which also brings up the subject does she leave the black tank open too? Cause that most likely has already created a mountain of poo waiting to clog and stink things up.
Both tanks closed and dumped when full. First Black and then gray.
coolmom42
John Wayne wrote:
I'm betting she leaves the gray tank valve open whens she's parked. liquids run out but solids build up. After you get it cleaned out have her leave then valve closed till the tank fills and has more liquid to flush out the sludge. Heavy treatment of Dawn dish soap drive around for a while and drain. If it takes oil off shore birds it should work on the sludge. Have her do the Dawn each time she changes parks.
This.
When she is parked, she should leave the gray (and black) tank closed until it's almost full. Then dump the black, dump the gray. Both will do much better that way.
Before moving, add 2 cups Borax or Calgon water softener, and a cup of laundry detergent or Dawn dish detergent, to each tank. I would think this would work best with the tanks about half full Drive and let that slosh around for a while. Then fill the tank and dump. Repeat this every time before moving.
A lot of people add this to every tank, moving or not.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
old_guy
walex elemonate and Happy camper are two very good chemicals to use in either tank. I had a cleanout installed in both the black and the grey tanks, they kept both tanks squeaky clean
SoundGuy
I've used Walex Elemonate in the grey tank for a couple of years now and have no tank issues at all. :B
2012 Silverado 1500 Crew Cab
2oldman
John_Wayne
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
JimK-NY
I bleach mine fairly frequently. The bleach gets rid of the odors and gunk. That might work eventually, but if it is really bad, I think I would try a septic tank treatment with enzymes.
rbrand
I would try hot water, TSP, then a High Pressure washer.
The less you plan the more options you have.
Currently with a 26' Forest River Class "C"
Ex Navy Diver
Ex Archaeologist
Ex Museologist
Actively retired
2oldman
RTrider wrote:
.. does not put anything but dish water and shower water into the grey tank. She does not have a dishwasher or clothes washer in the coach..
What's in the dish water? Grease is the big problem. Have you done a close inspection of the gray water?
Sounds like the tank needs a thorough cleaning.. but I don't know how that's done. I wouldn't have a problem getting a pressure wand in there as long as there's a way for air to escape. Either that or a lot of really hot water.
