Apr-06-2021 06:25 PM
Apr-19-2021 10:25 AM
Apr-19-2021 09:38 AM
BFL13 wrote:Eventually my BMS may have a monitor. However once initially set up I don't expect to use more than a voltmeter. I see no rocket science here. Again more capacity kills the need to watch the fuel tank. Just can't imagine a scenario where the voltmeter would not be able to give a full 24 hour warning that the battery is being depleted and power will be cut.
I suspect time2roll is suspecting he will now need more than just his voltmeter too, so over to you LFP guys on what to do----
Apr-19-2021 09:35 AM
BFL13 wrote:
How's this for a plan then?----
FWC was careful by saying, "the resting voltage is 13.2-13.3 " He did NOT say that was the "full resting voltage". He did say that as soon as a load is applied to a full LFP, the voltage drops to 13.3.
So 13.3v means anywhere from 99-89% SOC in effect. Then the voltage/SOC table time2roll posted (from BB's) could be used (except very difficult to get proper voltage with the temperature making that so sensitive, per FWC's note on that)
Then time2roll makes a very important point--you can see where the lower knee starts by watching your voltmeter.
How to use your AH counting monitor or smart shunt?
1. You get the battery as full as you can using its charging specs and guide for that.
2. Pick a number for your amps draw since Peukert is near 1 (FWC again) say 10 amps and hold that constant as you can while your AH counter counts down and you keep an eye on the voltage.
3. When voltage starts to drop off, stop!
Now you have your AH "allowance" that you can operate within. Using a variety of amp draws while camping, you still have the same total allowance. ( which is why the 20 hr rate doesn't really matter with Peukert at 1)
What do you enter as your "full" capacity on the monitor? Doesn't matter as long as it is more than your "allowance". Set your low voltage alarm at that voltage you saw where it started to drop off.
While camping, you can watch the AH counter count down and remember your allowance. You can do the math in your head to tell when you are half way down or three quarters the way down, etc.
OR, if you make your AH allowance your "full" entry on the monitor, and it reads your percentage SOC, you can use that. Just remember to zero/sync the monitor whenever you get the chance when the batt is as full as you can get it.
TA DA! Is that what you LFP guys do? ( Itinerant1 has a more complicated monitoring system that does include some cross-checking, but I am wondering what LFP guys with a simple system do)
jaycocreek is looking for suggestions and I suspect time2roll is suspecting he will now need more than just his voltmeter too, so over to you LFP guys on what to do----
Apr-19-2021 07:48 AM
FWC wrote:
How so? You could use lead acid and need 3-stage, temperature compensated charging, do your best to only use 1/2 the rated capacity so that they will last a reasonable period, remember you will only get a fraction of their capacity if you use them hard (peukert), remember to account for their voltage drop as you use them, and make sure you regularly charge them for 12 hours so they don't sulfonate.
The only reason folks think lithium chemistries are more complicated is that they have come to accept all the requirements of lead acid as 'normal'. In an apples to apples comparison the care and feeding of lithium is far simpler, most folks just aren't familiar with it.
Apr-19-2021 07:43 AM
Apr-19-2021 07:11 AM
StirCrazy wrote:FWC wrote:
PS the resting or 'nominal' voltage of LiFePO4 is NOT 13.6V. The resting voltage is 13.2 - 13.3 and the 'nominal' voltage is 12.8V.
thats kind of a bold and misleading statment. the resting voltage all depends on state of charge, if you are 100% charged then the resting voltage is 13.6V
Steve
Apr-19-2021 06:32 AM
Apr-19-2021 05:59 AM
Apr-19-2021 05:41 AM
Apr-19-2021 05:38 AM
BFL13 wrote:
Steve, thanks for the clarification. I was using CCA because it is the only thing I can think of with battery ratings that are a measure of its power. FWC said a battery's power is its max current at its nominal voltage (if I got that right) so 800CCA is twice the power of 400CCA.
I don't know where an RVer cares about power as such. Ads saying a battery has "twice the power" got me wondering what that is supposed to mean. Seems to be "Sales" talk. ?
That Odyssey 31 hybrid battery that allows a high draw makes that claim, and ISTR LFP ads saying that too.
Another puzzle is how they do AH with LFPs, but that only matters to those who operate them trying to keep track of usage while camping if they even do that.
EG, The blurbs say don't use Peukert, but still say the LFP is 100AH because they ran it down at 100 amps in 1 hour so that is 100AH. Then they sort of dance around saying it also takes 20 hours to run it down at 5 amps, so that is 100AH at the 20 hr rate. But no Peukert here folks! 🙂 It makes your head spin.
Then they start in with the Wh, but use the 12.8 nominal voltage to get the AH. OR----did they get the AH first and then invent the Wh????
In the previous example, it was 1536 Wh and 120 AH at 12.8v
The battery is full at 13.6v so that is where you have to start. Either:
A. the battery is really 1536/13.6 = 113AH , or
B. the battery is really 120AH so x 13.6 = 1632 Wh
Which is it? If you are monitoring by Wh usage or AH usage, I would think that is important for setting up your monitor.
Not a clue. so Steve, what are you going to do for operating your "280AH" battery for setting up a monitor? Just curious on my part, but other LFPers might be interested. ?
Apr-19-2021 05:31 AM
Apr-18-2021 09:22 PM
time2roll wrote:FWC wrote:Is it?
Apr-18-2021 09:04 PM
FWC wrote:Is it?
Apr-18-2021 08:53 PM
Apr-18-2021 08:36 PM
