2012 2500HD CC SB with 6.0L and 3.73 ratio
Frozen001
Hi all,
Took our first long trip with my newer tow vehicle. I went from a 2006 chevy Duramax to a 2012 6.0L gas with the 3.73 ratio. Now I fully understood there would be a difference due to it being a gas so that is not my issue here. But with a 5100lbs dry travel trailer(estimated 6500lbs max loaded) , I am no where near the limits of the truck.
Well like I started off, too our first long trip, Central NY to Maine. Towing on the highway at 65mph it would not shift to 6th gear. Is this typical for this setup? I am strongly considering swapping the gear ratio to the 4.10 depending on the cost.
In 5th gear I got like 8.5mpg which is what I expected, transmission was nice an cool typical temps in the 170-180 range, peaked at 186 climbing the Berkshires on the Mass turnpike, absolute max I seen was 196 when we slowed to a crawl in a traffic jam, but that was maybe 10 minutes.
2018 Chevrolet Silverado 2500HD CCSB 6.6l Duramax
2019 Grand Design 3170BH
2-Crazy Red Heads, an patient wife and me.
18 REPLIES 18
kw_00
I use the toggle switch for selecting gears when I need to. So in locking out 6th I run 5th, but will run in 4th below 60mph. I love the 6 speeds, really a great match with the GM 6.0..
A truck, a camper, a few toys, but most importantly a wonderful family.
Frozen001
Lantley wrote:
Funny this is not meant to be critical, what the OP describes and is happy with is exactly why I have a diesel. More shifting,more,revving and lower MPG's.
What I left out is the OP has lots more cash in his pocket after the sale which I totally understand. I also understand if you don't tow enough a diesel is just not money well spent.
Enjoy your new truck, it's nice to have options for every budget and camping style.
Yea I loved the diesel, but honestly the body on the 2006 was my problem, the drivers side under the carpet was total rust... traded it in before it got like that on the outside. The gas was a good deal, so considering I typically tow total about 3-4 weeks of the year and the cost different between diesel and gas in NY, I am actually saving money. Towing the same trailer with the diesel I was netting between 10-11mpg, so I honestly am not feeling the MPG loss.
The truck really does tow well, and honestly the ride is better than my 2006 was when towing. I do think it holds the gears a bit longer than needed ager cresting a hill sometimes, but then I tend to overthink things.
APT
I tow 65-70mph usually and use Tow/haul and M5 to lock out 6th gear. At 65mpg, 6th gear would be about 1700rpm and not enough power. 5th gear is 2200rpm @ 65mph, which seems low too but it holds on flats and overpasses. My last 4-spd truck towed was happy in 3rd gear at 2800rpm. I get 7-9mpg at my speeds.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
larry_barnhart
Nice response and very true
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Lantley
19'Duramax w/hips, 2022 Alliance Paradigm 390MP >BD3,r,22" Blackstone
r,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,Prog.50A surge ,Hughes autoformer
Porta Bote 8.0 Nissan, Sailun S637
Mr_Beebo
I have the 4.10 gears. 6th gear is not for towing. 8 1/2 mpg sounds about right. Honestly, the downshifts are smooth enough and the noise fairly subtle enough that I'm usually the only one who can notice it out of the four of us inside the cab.
2010 Rockwood Roo 23SS
2009 Silverado 2500 6.0
Taco
Mine will hold 6th gear for brief periods (a minute or two) on flat ground when the wind is right.
I just put it in D, push tow haul, set the cruise, and steer.
RCMAN46
Not likely a 4.1 would allow you to hold 6th gear.
Now a 4.76 will allow you to hold 6th gear. But your overall gear ratio from engine to wheel would be the same as with the 3.73 in 5th gear. Nothing really gained except when unloaded your mileage will suffer at 80 mph as is the posted speed limit in much of Idaho and Utah now.
Gearing does not make more horsepower!
N-Trouble
Your 2004 would have had the 4-speed and likely 4.10 gears. Apples to oranges...
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Frozen001
OK, sounds like all is good then.... The last 6.0 I has was a 2004 Reg cab/long box and only towed 3500 travel trailer, so I did not experience this. Pulled fine, although I thought the exhaust noise in the cab was somewhat loud under load, but that is just an annoyance.
kw_00
Normal, I always lock out 6th when towing, even in florida. I mainly pull in 5th and sometimes in 4th. Let the 6.0 pull in those gears instead, and when u hit 3 k rpm it really wakes up.....overall a really good engine. No problems pulling the weight that your towing...
ib516
I have 4.10s and never see 6th when towing.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
gmcsmoke
if towing with tow/haul on 6th gear upshift won't occur until 68MPH. Run it up to 68-70, let it shift and then settle in at 65.
N-Trouble
The 6.0 barely has enough low end torque to hold 6th unloaded let alone towing 6500lbs. The slightest hill and it will downshift. Leave it in 5th when towing... THat motor needs to rev
