5.3 vs 6.2
d1h
Nomad III
Nomad III
Been looking at 6.2L Chevy Silverados to replace my 5.3L. How much better of a job would the 6.2 compared to the 5.3 do especially when it comes to towing up mountains. My 5.3 really struggles with my 25ft TT going up steep hills or mountains.
25 REPLIES 25
Grit_dog
Navigator
Navigator
OP, sounds like youโ€™re largely confused still.
Simplify it for yourself.
Write down 4 numbers for your rig and the ones youโ€™re thinking about.
HP
TQ
# of trans gears
Rear axle ratio
The best overall combo of those numbers will tow the best.
And if youโ€™d actually do some searching here or research to be more well read rather than seeming to want rvnet to spoon feed you what you want to hear, it would help your understanding consider ably as well.
LITEPHIL
d1h wrote:
Appears from some of the posts that a later model six or eight speed transmission with the 5.3 does a better job of towing than an older model with a four speed. Mine is 2009 with the four speed. If a late model 5.3 will pull just as well as the 6.2 I could save a little money since you can only get the 6.2 on the more pricy LTZ and High Country.
The 5.3 will not pull as well as the 6.2 and you can now get the 6.2 on the lower level vehicles. But my 5.3 8 speed is pretty nice with 6,000 lbs.
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
d1h
Nomad III
Nomad III
poppa
kw/00 wrote:
spoon059 wrote:
OP, I'll throw a curve ball at you. Skip the 6.2 in the half ton and get a 6.0 in a 3/4 ton. You'll leave a couple HP on the table, but get a SOLID engine/transmission combo that is better for towing than the half ton.
I did that exact thing years ago and never have looked back. I still have my 09 HD 6.0 and with 98k on it so itโ€™s got along way till I sell it. In my opinion, the GM 6.0 with 6 speed combo is one of the best ever made.
the 3/4 ton suspension is much better for towing than the 1/2 ton, dosent matter on the engine size. i have the 6 ltr in a 3/4 ton crew with 4.10 gear and it tows good. likes the gas though
JIMNLIN
I did the same thing in '03 when I had a ....never mind that won't help the OP looking for more towing performance pulling a 25' TT. He doesn't need more load carrying capacity from a 3/4 ton truck for that size trailer.
OP your '09 5.3 1500 is down on towing power compared to the later model 1500 5.3 engines and especially the 6.2 engine.
Drive both if your looking at new trucks. Also the NHT option is GM max tow option. Gives the truck a bit more GVWR/RAWR and the lower gear ratio for towing duties. Actual final drive ratio depends on year models if your looking at used trucks.
kw_00
A truck, a camper, a few toys, but most importantly a wonderful family.
Grit_dog
Navigator
Navigator
Yes, power wise, very similar, but you're also leaving 4 gears on the table.
(I thick GM messed up by not dropping the 10 speed behind the new gasser. Just stupid since they have the trans sitting on the shelf for the diesels)
The consideration is the overall use of the truck.
I know you're reasonable and understand vehicle capabilities, and I don't disagree that the HD is a stouter platform, but if a guy is driving say 20k miles a year as a daily driver and only occasional towing, it makes no sense to run a 2500 vs a 1500 for a small trailer that is well under the 1/2 ton's rated capacities.
spoon059
2015 Ram CTD
2015 Jayco 29QBS
APT
IF you did a blind towing test of same year and geared truck, I think you'll notice the difference. You'll be able to hold a gear longer on slight inclines or maybe cruise at a lower gear. I highly recommend the 10-spd with either engine more importantly than the engine. I believe the 6.2L got the 10-spd standard before the 5.3L, so it may depend on which year you are looking. What year/axle is your current Silverado?
2017 Subaru Outback 3.6R
kellem
By simply avoiding the 4L60E is a step in right direction.
I've grenaded (4) in 20 yrs towing, no joke.
ksss
The money spent on the 6.2 upgrade will about pay for itself at trade in time if that matters.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
mooky_stinks
Lol at 5k difference. Unless you're including the difference between the LT and LTZ package that was/is required when I had mine? You get a lot more than just the engine upgrade. So it's a moot point if you're already getting an LTZ. It wasn't mentioned so I'm mentioning it now. I've had both a 5.3 and 6.2 in the last 3 years. The 6.2 w/ 8 speed was $2500 over the 5.3 w/ 6 speed. The 5.3 has 3.73's and does just fine in the east. The 6.2 w/ 3.42's of course was better but I decided against it this time. It really wasn't worth it to me. The 6.2 did get better mileage by 1-2 mpg both towing and non-towing. And it did REQUIRE 90 octane fuel to keep it from pinging, and yes I know the owners manual says "recommended" lol.
2020 F150 XL Screw 4x4 6.5โ€box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
BurbMan
You guys have been around here long enough to know that anything that smells like a gas vs. diesel thread will get shut down....but you make a good point about having that discussion on two gas engines.
The EcoBoost in our Explorer Sport takes premium too...it will tow, but you gotta pay to play...
JIMNLIN
6.32 vs 5.3 = apples vs oranges.
Later model '14 and up 5.3 have 355 hp 383 torque.
The 6.2 in 1500 GM trucks has 420 hp and 460 torque.
My wife has the new 5.3 in a 2016 1500 crew cab chevy 6 speed. I just came off a 318 mile (round trip) pulling a 10k car hauler with 9460 lbs on the trailers axles. Now it not up to my 2500 Dodge/Cummins performance but it hands down does a much better job pulling the same trailer combo on the same trip with her older '06 1500 5.3 chevy crew cab 4l60e. No comparo.
