ATTENTION ALL DURAMAX OWNERS
gat75
Just chg engine oil & filter in my 2009 D/A GMC 2500. Truck has 60,000 miles, purchased new the week before Thanksgiving in 2009.
* Poured in 10.5 qts of oil, (as I always have, per owner's manual)
* Checked oil before startup & found that level indicator was missing from end of steel cable on dipstick.
* Took to local GM dealer
* Was told that dipstick appeared to be broken off & lodged at bottom of dipstick tube.
* SERVICE WRITER told me that broken dipstick WAS NOT covered by GM's 5-year, 100,000 warranty.
* Diesel Mechanic said that tranny would need removal before oil pan could be removed (if piece had fell into pan).
* Mechanic said it would be 19 hours labor to retrieve the piece.
* I then went & read the warranty, it states that THE COMPLETE ENGINE ASSEMBLY IS COVERED BY THE WARRANTY.
* Went back to dealer, they agreed to fix truck.
* Will report back when I get truck back from shop.
* Found out that this is more common than you think. The level indicator is crimped onto the end of the steel cable.
16 REPLIES 16
Jarlaxle
I had the "loop" of the dipstick snap off on my Magnum, leaving the stick (the whole thing!) stuck in the tube. (Per my wife: my facial expression was truly priceless.)
I took it to the dealer, and nobody had ever seen THAT before...after the service manager and every mechanic in the shop tried (unsuccessfully) to fish it out with pliers, they said they'd have to pull the tube. They wanted me to leave it overnight so they could work on a cool engine. (Which I found entirely reasonable.)
They wound up replacing the dipstick and the tube...the service manager gave me a free loaner (PT Cruiser), all I had to pay for was about $30 for the replacement dipstick. (The car was out of warranty.)
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. 😞
Current rig:
1992 International Genesis school bus conversion
BurbMan
Another 6 weeks and you would have been outside the 5 yr warranty period. Glad you were able to get it fixed.
I had to change the pan gasket on DD's 98 Grand Prix 3.8 and when I pulled the pan there was an old time-sert and a bunch of metal shavings in the pickup screen. Not ideal, but the screen was keeping them out of harm's way. 160k miles on the car, uses no oil, who knows how long they have been in there, and what mechanic installed a new time-sert by sending the old one into the pan...
caberto
I had heard of this happening with the dip sticks on Duramax trucks back in 2005 when mine was new, so I've always been "gentle" when retrieving the dip stick, no harsh pulls (haha, I just re-read that - no funny comments! :W ). I don't know why they went this route with those tips.
2010 Keystone Cougar 324RLB
2005 GMC 2500HD Duramax/Allison 4x4 Crew Cab S/B
www.imagesbyberto.com
________________________________
RZAR66
I had this happen to me on a new Caterpillar engine a few years ago. End of the dip stick was stuck in the tube. I bought a new dip stick and used that to force the broken piece into the oil pan. I then drained the engine oil into a clean pan and rubbed a strong speaker magnet on the bottom of the oil pan to fish the broken piece out the drain hole.
2018 Ford F-350 DRW
2024 Northern Lite 10-2
gat75
GM dealer removed dipstick tube, however, did not find end of dipstick in end of tube as expected.
* They removed both pans, found & removed the piece, installed new dipstick.
* When I got truck home, I looked under truck, did not appear to me that the tranny was removed.
* I did see fresh sealant on both of the pans.
* I would have been happy to have left broken off piece in the bottom of the pan, however, the lead mechanic told me he could not guarantee 100% that the piece might cause trouble in the future.
* MORAL OF THIS STORY, CHECK END OF DIPSTICK AT LEAST EVERY OIL CHANGE, (IF NOT SOONER) TO ENSURE THAT OIL INDICATOR HAS NOT "SLIPPED" ON END OF STEEL CABLE.
Even considering this issue, this truck has been very dependable, (Quite unlike my previous 2001 FORD P-stroke that had tranny removed 4 times in 120,000 miles). Not bashing anyone, just stating the truth.
The ford rode better, had better interior, just was not mechanically dependable, (considering I was only pulling a 27.5 mid-profile Prowler part-time).
Hybridhunter
ksss wrote:
smkettner wrote:
OTOH I think that item could float around on the bottom of the pan forever without harm.
Now you will have a reassembled lower engine that IMO is more prone to leak. Hand me a new dipstick and I would be on my way.
As would I, I would not let them pull the engine to retrieve that. I certainly would never pay myself to have it done.
Yep. It should sit in the screen forever, no issue. Leave that sucker together.
ksss
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
time2roll
christopherglen
I got an oil leak between the upper and lower pans on my 07 classic, they removed the cross member, then the lower pan. In and out in less then 2 hours..
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
N-Trouble
Interesting... I follow Dmax discussion forums fairly closely but have never hear of this happening.
Agree on trying to remove the dipstick tube FIRST before committing to an entire engine dis-assemble.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
badercubed
ScottG wrote:
The sad thing is they will all try to pull that sort of thing - regardless of brand.
Ehhhh, I'd argue is mainly based on the dealer, not the brand. My dealer tries to do EVERYTHING under warranty.
2019 Apex Nano 208BHS
2016 F-150 Crew Cab (it's my wife's ride)
Been camping for 37 of my 38 years!
bguy
brownieab wrote:
If the indicator is lodged in the dipstick tube, remove the tube and see if indicator is still there
Yup.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
brownieab
ib516
Glad you got it straightened out.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
