โAug-11-2014 05:43 PM
โAug-13-2014 06:34 PM
tll wrote:
I did a little investigation into the side to side motion problem with the Lippert electric stabilizing jacks. For the self adjusting part to adjust to uneven ground, the jack carriage has to slide back and forth. After the jacks are down and under pressure, movement in the trailer causes the trailer to rock back and forth on the carriage. Stopping this movement should solve the problem. I believe a set of JT Strongarms or similar might do the trick. I think I will order a set of the BAL brand ones to put on the rear jacks and see how it works. See the video attached. The jacks are under pressure, and my daughter is aggressively stepping on and off the rear steps. It is the trailer that is moving, not the screw jack assemblies.
Lippert jack movement
โAug-12-2014 06:40 PM
โAug-12-2014 05:56 PM
โAug-12-2014 07:11 AM
โAug-12-2014 05:56 AM
โAug-12-2014 04:17 AM
tll wrote:
I am not really happy with mine either. They have not failed, and they do support the front and back of the trailer, but they sure don't stabilize it much. Very disappointed in them. I have been trying to troubleshoot why they don't stabilize the trailer and it appears the carriage that holds the jacks and screw system slides back and forth on the mounting brackets causing the trailer to move. I have cranked the jacks down harder and harder, and it does no good. My wife keeps talking about getting sea-sick whenever someone moves:)
โAug-12-2014 03:15 AM
โAug-11-2014 10:03 PM
โAug-11-2014 10:00 PM
โAug-11-2014 09:56 PM
crickeydog wrote:
I guess that's (Lippert) what we have on the rear of our 5'er. .... Whatever brand they are they've worked fine for close to 11 years now and stabilize our 5'er just fine.
โAug-11-2014 08:22 PM
โAug-11-2014 06:56 PM
โAug-11-2014 06:04 PM
โAug-11-2014 05:57 PM
