Sep-02-2014 01:36 PM
Sep-04-2014 01:02 PM
BenK wrote:
You should rename the title to: "how can I change my rear GAWR"
Didn't mention the third 14 bolt in the GM parts bin, because of your
TV's era. Of the three 14 bolts in the GM parts bin that I know of,
are the 9.5" ring dia, 10.5" ring dia, and the 11.5" ring dia
Within all of them are varying parts bolted on by GM from the base
axle assembly supplied by an external OEM
GM rates these from 6K GAWR to 10K GAWR....IIRC
Folks who can eyeball a leaf spring to know it's static pre-stressed arch;
thickness; tapper; width; etc have better eyeballs than I do...
Yes you *CAN* change the GAWR, but it might cost you more than going
out and buying a new truck
The ME/PE (mechanical engineer, profession engineer) will need to
redesign and then certify their engineering. Then a shop will need to
make whatever mod's per that new specification. Then have all that
checked by the ME/PE and whatever certification agency deemed necessary
Then they will make up a new door label for you with the new GAWR
As for the PSI loading on the pavement, yes very true and accurate,
but that is only one in the food chain from the frame down to pavement
Changing one component of the system 'might' do it, but then you will
need to know that it was the weak link in that food chain down to pavement...
To then find the 'NEW' weak link that will then become the limiting
factor of that food chain...and so no and so on...
I understand overloading a rear axle beyond it's RGAWR...I replace
the rear axle bearings on my 1980 Silverado often, as I over load it
often. Do have 1 ton helper coil springs on the axle bump stop perch
to frame. It does not squat much with a +2,400 lb load. Do have
performance level braking and 33/12.5R15LT load range C tires on
15x8.5 alloys.
That kind of overloading doesn't break it instantly, but takes the
axle bearing out in a couple of years...dependent on how often...how
much over...how fast I've driven over loaded...etccbwallace wrote:
I was reading another post and it got me wondering... I have a 2013 2500 HD with a rear GAWR of 6200 lbs. I have 265/70R18E Michelin's with a max load of 3525@80 psi per tire giving me a tire load capacity of 7050 per axle. The 3500's use the same axle and came standard with the 265/70R18E Michelin's, but the 3500's have a rear GAWR of 7050. Is there a difference in the load capacity of the wheels? If not, why the difference in rear GAWR? I also have to wonder why GAWR doesn't differ depending on what tire option a truck has from the factory.
In theory, shouldn't I be able to safely handle a rear GAWR of 7050 if I had air bags?
For the record, I have been to the scales and I am well within my weight ratings!
Sep-04-2014 12:53 PM
Sep-04-2014 10:56 AM
Sep-03-2014 10:40 PM
Sep-03-2014 07:50 AM
Sep-03-2014 07:28 AM
Sep-03-2014 06:57 AM
ScottG wrote:ib516 wrote:
My buddy has a 2014 Ram 3500 SRW/Cummins 4x4.
It has the exact same wheels and tires (size, type, brand) as my truck, but has 500# more rear GAWR (6500# to his 7000#). Must be the springs.
If your friend has an 2014 HO the ring gear in the diff is bigger than yours and either way, he has different and bigger wheels (18") than you and while I'm not positive, I think he has bigger brakes than your 07 has.
Sep-03-2014 06:22 AM
BenK wrote:
another factor is the diff ring gear dia and the subsequent axle
bearing size. There are TWO 14 bolt diff's that GM puts in +8K GVWR trucks/SUVs
Note that the OEM that supplies the rear axle assembly for my GMT400
rates it at 10,000 lb GAWR
so why does GM rate it for 6,000 lb GAWR?...yes, that is the sum of
the tire's max weight rating, but does that mean if I put in 4,000 lb
rated tires it would now be rated 8,000 lb GAWR?
Mine is also the same axle assembly for the 1 ton dually of my year and it
too is rated 6,000 lb GAWR...so the exact same?
Nope, the MC bores are larger on the 1 ton dually. The rear brake drum
dia are the same, but some 8,600 GVWR Sub's have that same dia, but
2.5" wide shoes/drums...while others and the 1 ton dually has the
same dia drum, but 3.5" wide shoes/drums. The rear brake cylinder bores
are also larger. The brake proportioning valve body are also different
It's not any one component of the 'system', but the whole system that
dictates
Sep-02-2014 06:25 PM
Sep-02-2014 06:10 PM
Sep-02-2014 03:35 PM
Sep-02-2014 03:16 PM
Sep-02-2014 03:15 PM
Sep-02-2014 03:09 PM
gmcsmoke wrote:
there's no difference in the wheels the rear axle is derated to fit under the lowered GVWR. The FAWR is the same for both 25/3500 trucks.
