โJan-31-2021 07:24 AM
โFeb-05-2021 03:41 PM
โFeb-05-2021 08:51 AM
Grit dog wrote:
This is like a bad joke.
โHow many rv.net members does it take to change a flat tire?โ
Answer: None of them. Theyโll never stop arguing long enough to actually change the tire!
โFeb-05-2021 05:36 AM
โFeb-05-2021 03:38 AM
jaycocreek wrote:
Safe Jack for RV'S
BENEFITS
Increases safety
Makes jacking easy in a variety of ways
More stable, and secure
Extends the range and usefulness of the jack
Compact easy to carry and stow
Easy to use
FEATURES
Lift range of 9.5" โ 25"
Designed for RV's 24,000 - 48,000 GVW.
Extension Screw Collar provides max useful stroke
Extensions and jack pads can be combined in any combination
Lift at an axle, frame or other lift point
Durable steel construction
Additional extensions can be added to increase lift range
Extensions and pads are always made in the USA
Grit dog wrote:
I'm now not sure if you're for or against lifting from the axle.....and I suspect you aren't either!
โFeb-04-2021 02:34 PM
jaycocreek wrote:
Safe Jack for RV'S
BENEFITS
Increases safety
Easy to use
FEATURES
CB
Channel 17Redneck Express
โFeb-04-2021 02:28 PM
Kayteg1 wrote:
It is dog chasing its tail only becouse we like to troll here.
Here is picture from my truck manual.
It is generic picture, not showing details, but clearly shows jack under suspension bracket.
The note saysmanual wrote:
Rear
Note: Jack at the specified locations to avoid damage to the vehicle
Any more questions?
โFeb-04-2021 01:22 PM
โFeb-04-2021 09:49 AM
manual wrote:
Rear
โFeb-04-2021 09:26 AM
โFeb-04-2021 09:22 AM
โFeb-04-2021 08:35 AM
โFeb-04-2021 08:21 AM
โFeb-04-2021 06:52 AM
jaycocreek wrote:most of the cases there is not clear description how the bend happened, it would surprise me if someone come to the internet forum admitting he bend his axle with stupid jack positioning.
Uh huh...
I can guarantee you I have changed more than my share of tires and once did it for a living at Sears auto/tire..Never seen anything like you describe and I come from logging communities where things are treated rough and overloaded to boot..Common sense must be the dividing factor in bending or not bending an axle housing with a bottle jack and being sober helps.I have heard..LOL
Have you bent one or are you relying on the internet to back up your opinion...I want to see one where the axle housing was bent using a bottle jack because that is what we are talking about..
