How to keep a TC from being stolen when not on the truck?
Jedidad
How do you keep someone from backing their truck under your TC and hauling it off when it's on the jacks and you're not around?
35 REPLIES 35
ronharmless
joelc wrote:
Don't know about a trailer, but there is a lock that goes around the hitch pin on a 5er and I assume that they would have a like lock for a trailer coupling. They would have to destroy the hitch to get the lock off. Then of course, they could not steal it anyway.
Youโ€™re assuming that a thief that was out trying to find a fifth wheel to steal wouldnโ€™t have a battery powered cutoff tool (or torch - if heโ€™s really serious) with him. Ever hear about the catalytic converter thefts? However, any thief that is going to target a TC, 5er, or trailer is going to want to have that particular unit pretty badly to begin with, because they are not normally easy targets for a quick buck.
Bedlam
Moderator
Moderator
You biggest worry will be battery and propane tank theft rather than the unit.
StirCrazy
Moderator
Moderator
mellow wrote:
I will lower it down so it is more stable, that and a truck can't get under it. I have powered jacks. If someone wants it bad enough they can still break in and power up the jacks from inside if they find the remote and know what they are doing. If you are worried about that happening I would put a tracking device in the camper or an airtag at a minimum.
or just declutch them and use a drill with a end like the manual crank has, disconecting the batteries or hiding the remote won't stop the ability you run the jacks by hand.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
deltabravo
Geo*Boy wrote:
srschang wrote:
I don't worry about it.
This^^^^
Ditto.
dalej
I used to disconnect the batteries that are in a locked compartment.
2005 Chevy HD2500, ext cab, 4x4, 8.1, allison,lwb,srw, 265 75 16's, timbrens
joelc
ronharmless
Whatโ€™s to stop someone from stealing a fifth wheel, travel trailer, Motorhome, etc.? IMHO it seems to be pretty much a nonissue. Stick dog appears to have the best answer.
JRscooby
greenno wrote:
If I dropped it off out in the boonies for whatever reason and somebody attempted to heist it I always carry a firearm and I always carry a shovel.
Do the math.
I would love to hear how the tools would work. If you have left the camper, with some kind of trap set...
stickdog
Something my daddy taught me years ago. If you can't afford to replace it, insure it.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
jimh406
I think it's more about where you park it than what you do to prevent destroying/removing it.
Most vehicles aren't capable of hauling mine off, so I'm going with not worried about someone stealing it. I keep the jack remote in my truck, so if the TC is lowered, they have almost zero chance of taking it.
I think the bigger concern is breaking into it to steal things for their local pawn shop or craigslist. That goes back to where you leave it. Most campgrounds in semi rural areas are going to be pretty safe with lots of other RVs around. It's more likely that they break into the other more typical RVs.
Adding a proximity alarm probably wouldn't be a bad idea which might stop someone from breaking in.
Chuck_and_Di
I'd be curious to see a reference to this ever happening. I'd wager most thieves would not even know how to load it, let alone have a truck to carry it. There are far easier things to steal.
wnjj
Jedidad wrote:
Itโ€™s not worry, itโ€™s precaution. I lock my truck when I go to a restaurant etc. I lock my house when I leave.
Sure, but you canโ€™t stop someone with a rollback from hauling away your locked truck. Thatโ€™s more likely than anyone trying to haul away a camper.
Buzzcut1
Nomad II
Nomad II
And you lock your camper. That said never leave your camper off the truck with the jacks extended. Always lower it to the point where the back bumper is just a few inches off the ground. Then take the remote with you in the truck if that's what you need for piece of mind
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Jedidad
Grit_dog
Navigator
Navigator
This be a funny threadโ€ฆ
