Just had a brainstorm - how about a survey!
DutchmenSport
I just had a brainstorm when reading through the posts here.
So here's my question. We have two groups of folks on these forums: Those who exclusively blow out their water lines when winterizing and those who use the "pink stuff". For purposes of this survey, if you use a combination of blow and pink, you're still using the pink stuff.
Here's my curiosity: Is it because of the pink-stuff (taste, chemicals, or whatever) you do not drink from your own system?
So here's the survey question:
Do you "blow-out" or "pink-up" to winterize. And the second response, when you have de-winterized your system in the spring, do you drink or not drink from your camper?
If you do not drink from your own camper's water system, why?
Let's have fun folks, no jabbing each other, please?
I'll start:
Pink-up and drink. (I'm too old and too cheap to buy bottled water so I drink - but I did buy an in-line water filter this year too)
129 REPLIES 129
aftermath
Blow and drink. Last trailer, pink and drink. I have had broken sink sprayers in both of my trailers! Operator error both times. Both systems work if done properly. Both fail if not.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
TOOBOLD
Pink, sanitize and bottle water. I do brush my teeth and also do dishes with the water in the system.
Mvander
Blow, pink and drink. In that order.
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
Jbechtoldt
Pink and drink bottle water
2007 312BHBS Wildwood LA by Forrest River
2006 GMC 2500HD Extended Cab 4x4, LBZ Duramax w/Allison, Air Lift air bags, Bilstein's, Tonneau cover, Prodigy
Dennis_Smith
blow twice, athen pink, and yes I drink the water, even out of a old garden hose
MNRon
Pink and drink (after sanitizing with bleach in spring). FWIW - I used to be a blow and drink type for years until having a cracked fitting under the sink 3 years ago.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
DutchmenSport
Coming pretty fast here, but here's what we all look like. I'll update again in the morning.
wrvond
My old TT got the blow and don't drink treatment - no pink. The motorhome got the pink - no drink.
Our new unit did not get blown clear; I used the low point drains and tank drain that all actually worked, then I used that nifty pickup tube on the pump and filled all the lines and traps with pink stuff. Come spring, I'll sanitize. I'm also going to install a kitchen sink fountain with it's own .001 micron filter for drinking.
2022 Keystone Cougar 24RDS
2023 Ram 6.7L Laramie Mega Cab
brirene
Pink, no drink. Use bottled water. I do sanitize the system at least once in the spring too.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
pasusan
Blow, no pink, and don't drink.
(We bring jugs of filtered water from home to drink - I actually got sick a couple of times drinking water at CGs.)
Susan & Ben [2004 Roadtrek 170]
href="https://sites.google.com/view/pasusan-trips/home" target="_blank">Trip Pics
oldtrojan66
Blow out and partial pink fill. Sanitize in the spring after removing pink, I use vinegar, since I don't like even the thought of chlorine to drink. I still don't drink much, but use a Britta filter for coffee.
2007 Jayco Designer 36RLTS
2006 F350 DRW 6.0 PSD (powerstrokehelp.com)
When you're born, everyone is smiling and you're crying. Live so that when you die everyone else is crying and you're smiling!
skipnchar
I use antifreeze without blowing out lines. The reason I use antifreeze is that I have had broken check valve and broken deverter on shower when blowing out lines instead of using it. I always drink water from my system but my trailer has a water filtration system. For what it's worth I drank from previous rvs also and they did not have filtration. No bad taste in water with proper flushing which includes sanitizing the system.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
carpetguy2
I use a small shop vac to blow my lines out .and use pink to be safe
Don't drink
2007.5 chevy 3500 ltz CC LB Duramax
2016 Open range 3x378
Some other toys too
Steeljag
I do nadda / zippo / zilch / here in Florida!
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
SteveAE
Blow and Drink.
Sure hope no one reads this out of context:)
