Dec-23-2013 05:03 PM
Dec-24-2013 06:02 PM
blt2ski wrote:I have as of yet not towed in Washington State, but if I was to with my Indiana registered rig, then I would need to stop at the scales. Is that right?
I some, if not most or many parts of the US, the what some are calling commercial vs private law, is not that black and white per say. THey are one and the same as to how much you can legally put on a given axel etc. Be you using a class 8 tandem tractor to pull a large 5w. Or a converted diesel pusher bus to an RV. ALL of these people driving these rigs, need to stay below the FBL axel wts to be legal of pulled over, go thru a scale house etc. If over, they "should" get an overwt ticket just as commercial drivers do! That is how it at least works here in Washington. There is not private RV laws vs commercial. Having looked at and read the FBL's, there is no distinction from an actual how we are all to be enforced.
Yes, private rigs do not need special licenses, nor do they need to follow hrs driving......but there vehicles need to follow the laws for ANY rig over 10K gvw! At here I do. I can not tow of have my 3500 at or above 10K lbs, and follow the speed limit 70 mph sign were legal, I need to follow the truck 60 mph speed limit! same with chaining up in the winter. chains required over 10K, does not matter what I am driving or pulling, if the total is over 10K, I need to chain up.
Marty
Dec-24-2013 05:59 PM
Dec-24-2013 05:13 PM
Dec-24-2013 05:09 PM
Me Again wrote:
Well I have been looking for several hours at BC documents and can not find a reg that the FAQ are based on. So someone please point me to the law. Thanks Chris
Dec-24-2013 04:56 PM
Dec-24-2013 04:25 PM
jmtandem wrote:They THEN have to, if they can, move the load so that it is spread over ALL the axels under the max per the road stress limits. The driver will have 8 hrs if they can do it by hand, simple tools etc.
Sometimes sliding the tandems is all that is needed to reposition the load and get weights within the 12, 34 and 34 maximums. I think drivers know how much each hole on the tandems changes/shifts the weights.
Dec-24-2013 04:22 PM
jmtandem wrote:
I don't understand why you would think that erring on the safe side is something that bothers you. I would think a prudent person would encourage it. Even the Bible says that there is wisdom in the counsel of many.
donn0128 wrote:
How many people can "estimate" the stuff they load into their RV within 500 pounds? Darn few. I see nothing wrong to take a trailers GVWR as your starting point. While is may be unlikely that a person will hit the GVWR ( but I do) trying to guess how much your stuff weighs is going to make a person crazy.
To me your post is a lot of smoke and mirrors designed to help people justify overloading their TV instead of addressing the real issue and having the correct tool for the job.
APT wrote:
No one buys the "Base Curb Weight" vehicle.
sch911 wrote:
There is no 80% rule. You can run right up to the maximum ratings. .
LarryJM wrote:
While there might not be any "WRITTEN LAWS" directly related to GVWR issues I can easily see how operating a vehicle outside the FMVSS certified limits could easily be considered "NEGLIGENT" or "RECKLESS" operation of a motor vehicle in a CIVIL and even a possible CRIMINAL legal proceeding
Larry
Dec-24-2013 03:31 PM
Dec-24-2013 02:15 PM
Dec-24-2013 01:58 PM
Dec-24-2013 01:30 PM
Me Again wrote:
Here is an interesting one. *Alberta Transportation recommends that you do not exceed any of the three ratings
Read page four.
http://www.transportation.alberta.ca/Content/docType41/Production/recvehtowguide.pdf
and another
http://www.novascotia.ca/just/regulations/regs/mvwd.htm#TOC1_5
Look at table 2 page 14 in this one:
http://www.highwaysafetyroundtable.ca/member/documents/RAC%20Heavy%20Truck%2003.pdf
Chris
Dec-24-2013 01:12 PM
06Fargo wrote:
In any case I'm still saving up for a Kenworth dually.:) In AB I can license a 2 axle class 8 as a private vehicle at 32,000 lbs. It will have a GVWR of 80,000lbs on the door sticker. It won't have four wheel drive and will get stuck on wet grass, but I'm sure it will be much safer than my little truck. Once we get out of the yard on a damp morning :).
Dec-24-2013 01:09 PM
wilber1 wrote:Me Again wrote:wilber1 wrote:Me Again wrote:wilber1 wrote:
Licensing for a different GVWR than placarded is intended for commercial operators.
In the State of Washington ALL pickups at licensed at 1.5 tare weight rounded to the next higher even ton.
Commercial or private makes no difference.
Regarding GVWR in BC, Jimnlin has posted a number of times about that, and points to where that ruling actually points to standard weight laws and LEO's doing the GVWR thing are mis-informed!
Chris
FAQ's GVWR in BC
OK, here is a post made by jimnlin back in March:
"RV folks sure get confused on BC weight regulations actually says.
The link supplied by VintageRacer is a information sheet only and is not regulatory or a written law. There are 2-3 other versions BC has floating around the net. But they all tell us quote;
"This information sheet is intended to assist you. Should conflict arise please refer to the Motor Vehicle Act and Regulation".
Now we go to BC Motor Vehicle Act and Regulations and regulation;
section 19.05; ......(snipped for length)
(2) The driver of a vehicle on a highway, when directed by a traffic sign on the highway to drive over scales, shall drive the vehicle to the scales for the purpose of weighing the whole or part thereof by means of stationary or portable scales, measuring the dimensions of the vehicle and load, measuring and inspecting the tires thereon, inspecting the load carried, or for any purpose under this Act or regulations.
(3) The gross weight of any tandem axles and the gross weight of any group of axles shall be the sum of the gross axle weights of all the axles comprising the tandem axles or the group of axles, as the case may be.
(4) The gross weight of any vehicle or combination of vehicles shall be the sum of the individual gross axle weights of all the axles of the vehicle or combination of vehicles.
(en. B.C. Reg. 68/71, s. 5; am. B.C. Regs. 413/97, App. 1, s. 11; 135/2003, s. 6.)
As in any state or province stay under the trucks axle/tire load ratings.
One thing I've noticed is that folks from BC say they are required to register their trucks at a "GVWR". The GVWR can be up to the sum of the vehicles axle ratings (GAWRs).
However as long as your registered according to your states requirement you will be fine going through BC or anywhere. "
Chris
I read that to and it is in the commercial vehicles section. I do agree that there is confusion regarding RV's in BC but it seems quite clear that you cannot register your vehicle for any more than it's combined axle ratings.
Dec-24-2013 12:59 PM
Dec-24-2013 12:49 PM
