Safe towing limits for Ram 1500 3.6L v6
wildwildwest61
We have a Ram 1500 quad cab 3.6L v6 with GVWR of 6950. We currently have a 19' TT with GVWR of 4200 lbs, dry weight of 2660, hitch weight of 250. Exterior height is 8' 10". All is well as far as towing.
We are hoping to upgrade this year to a 26' TT, GVWR 6000, dry 4320, hitch 530. Exterior height 10' 8".
Is this a reasonable, safe tow vehicle for this bigger size TT? Anyone here have a similar combination with feedback to share?
We will eventually be getting a bigger truck, but that'll be a few years and I don't want to buy a TT now only to find we are under-powered. Camper dealership says we're fine...but they're trying to sell campers so I don't totally trust them. 😉
29 REPLIES 29
jerem0621
GCVWR should be in the owners manual.
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
ScottG
JIMNLIN wrote:
You should pay attention to the Gross Combined Vehicle Weight (GCVR), which is vehicle weight plus trailer. I should be on the driver door stickers.
FYI.....There is no GCWR number stickered on any truck.
The drivers side door tag certification sticker has GVWR/FAWR/RAWR only.
There isn't a sticker on the truck itself but there is indeed a rating.
JIMNLIN
TurnThePage
I think you'll be plenty safe. The truck itself is more than a match for the trailer you're considering. That engine is probably OK too. It's just not going to win any races. I didn't notice if you mentioned the year or which transmission you have. If it's the 8 speed, I think you might be just fine.
If I were you, I'd go by the owners manual and reference stickers in the the driver door jam.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
wildwildwest61
Thanks for the feedback. This is what I was worried about. I want to be safe and have enough power to not worry about making it up the next steep hill. Sounds like we better wait until we are ready to upgrade our truck too. Looks like another year in our itty bitty camper!
1320Fastback
It will not be fun, it will not be efficient but you could do it.
Recommend upgrading to E rated tires and possibly stronger rims as they most likely will be overloaded, airbags might be needed also.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
old_guy
I don't know why anyone would tow with 3:55 gears. just not enough gears to tow anything bigger than the truck itself. that's my opinion
Chuck_thehammer
can it do it.. sure..
I had the Ram 1500 with manual transmission and the V6... my 3,500 pound travel trailer was about Max in WV hills...
second gear and 5,000 rpms for 40 mph. up hills
yes I had the 3.55 gears.
plan on a bigger truck time.
Frostbitte
What ib516 said...
2011 RAM 3500 Laramie 4x4 6.7 Cummins 6-speed Auto 4.10
2004 Prowler 275 CKS (Sold)
2014 Sabre 36QBOK-7 5th wheel
2016 Forest River 8 x 20 Cargo Trailer
jerem0621
With 3.55 gears you are good to go up to 7,000 lbs.
I have the Pentastar in my van and have drove a few Rams with the Pentastar. They are more powerful than my current 4.6 V8 and should do the job.
It will not do as well as a Hemi and you will need to let it Rev. Just keep it in spec.
Thanks!
Jeremiah
TT - Zinger 270BH
~Walt Disney~
ScottG
I honestly don't think your going to like that combination.
jim1632
I suspect the V6 is just not up to a larger trailer.
Tankcar
Hello! What is the door sticker say?
ib516
For short, local trips on flatish ground, you'll be fine. You'll be hating life if you try long distance, mountain towing, or if you fight much of a head wind.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
SoundGuy
Hard to imagine you'd be happy with that li'l V6 attempting to tow that size of trailer. 😞
BTW, those hitch weights you're quoting are dry weights and not even close to actual gross tongue weight with the trailer loaded & ready to camp. :E
2012 Silverado 1500 Crew Cab
