โAug-12-2016 05:20 AM
โAug-17-2016 04:29 PM
โAug-17-2016 10:19 AM
โAug-17-2016 09:27 AM
dewey02 wrote:
My 2002 2500 Ram 2WD has 80lbs rear, 50 lbs front.
GAWR rear = 6084, GAWR front = 4410
Tires are LT245/75R16E.
(Just in case you need something beyond 10 years old)
โAug-17-2016 08:44 AM
โAug-17-2016 08:39 AM
wanderingbob wrote:
I do not understand the problem ! On my 2014 once I decide what pressure is aceptable to me , I then turn key off and on several times and the truck accepts it .
โAug-17-2016 06:02 AM
โAug-12-2016 03:11 PM
โAug-12-2016 01:08 PM
wanderingbob wrote:how many is 'several'? What model?
โAug-12-2016 12:38 PM
โAug-12-2016 11:21 AM
Grit dog wrote:I think I am as well.. I LOATHE the yellow 'tow/haul' indicator on my dash.. to me yellow means caution... I pushed the derned button.. make the indicator green or put it on the button....
But then again I'm ocd about idiot lights on the dash.
โAug-12-2016 11:09 AM
โAug-12-2016 07:45 AM
โAug-12-2016 07:44 AM
โAug-12-2016 07:43 AM
โAug-12-2016 07:31 AM
Me Again wrote:Capital idea! I haven't had any similar problem with my 1500, I can run the tires at 32PSI no problem, TPMS seems to kick in around 30 (haven't really confirmed that). I can see this being a HUGE program for 3/4ton and larger though....
Maybe go to www.safercar.gov and file a complaint that the truck is unsafe to drive unloaded because you can not lower rear tire pressure. Stating that the over inflated rear tires effects handle, decrease braking and are subject to impact damage when over inflated. Chris
