Aug-23-2020 03:46 PM
Aug-27-2020 08:55 PM
Aug-25-2020 06:00 PM
Aug-25-2020 04:27 PM
Aug-25-2020 09:30 AM
Aug-24-2020 10:03 AM
Aug-24-2020 09:58 AM
OregonMan wrote:Along with adding a second battery it is also time to review your charging system. Many converters are very slow needing 6 to 12+ hours for 95% charge. The common WFCO 3 stage is notorious for never going to boost mode (14.4v) when expected. Normal mode (13.6v) is just a trickle charge after 30 minutes. Post your converter model for best answers.
Basically I'm looking for solutions to boondock for longer. I've got solar and a power generator but a better battery setup would be great. Thanks for any tips!
Aug-24-2020 09:53 AM
naturist wrote:I concur with this as a small TT owner
The OP has a small TT. He doesn’t have either space or payload capacity for some of those suggested setups. The single 12 volt “marine deep cycle” battery provided with his TT is a 75 or 80 AH battery which was used in the first place because it was the cheapest battery possible.
With the (also cheap) WIFCO converter, he’s getting maybe 25 or 30 AH service out of that battery. For less than $400, he could buy a 125 AH group 31 true deep cycle 12 volt AGM and a real 30 amp battery charger to make sure it was fully charged. This would at least double his available power. Add a second such battery for another $250, and get 4 times the available power.
But even better would be just one such battery and 200 watts of solar panels. That should keep him in power indefinitely. Cost, about $650 plus installation. Operating cost, zero.
Battery
Charge controller
Solar panels
Aug-24-2020 05:29 AM
Aug-23-2020 10:30 PM
Aug-23-2020 09:59 PM
Aug-23-2020 08:19 PM
Aug-23-2020 06:59 PM
OregonMan wrote:
Hey guys, I'm wondering what your battery setup is on your travel trailer. I have a 2018 Wolf Pup 16BHS travel trailer and am still using the original battery which I believe is a 12 volt deep cycle. However I've never been impressed with the battery... on a full charge it lasts maybe a day with moderate use. Do any of you have a multi-battery setup where you have 2 or 3 batteries for longer use? Are there bigger batteries? Could you install a Tesla power wall on your trailer? 😉
Aug-23-2020 06:22 PM
Aug-23-2020 04:35 PM
