Feb-02-2015 11:55 AM
Feb-03-2015 04:30 PM
Feb-03-2015 04:19 PM
Feb-03-2015 03:59 PM
Feb-03-2015 03:52 PM
Feb-03-2015 03:26 PM
Feb-03-2015 03:18 PM
Feb-03-2015 03:08 PM
TomG2 wrote:spoon059 wrote:
....SNIP.......
My Tundra weighs 6000ish pounds and lets say I tow a 9000 lbs trailer. I've got 15,000 lbs combined as I descend this fictitious mountain when my brakes go out.
Someone else has a Ram 3500 dually that weighs 7500 lbs (curb weight, not including any gear) and is towing a trailer that weighs 30,000 lbs. That Ram has 37,500 lbs combined as they descend this fictitious mountain when their brakes go out.
Now... you are telling me that the 37,000 lbs Ram will stop in a shorter distance than the 15,000 lbs Tundra will?
...SNIP......
Now... who is pushing hyperbole on these forums?
You did not read what I wrote. If both tow vehicles are towing a 9,000 pound trailer which has less than perfect brakes, the 3500 will provide more braking capacity. Electric brakes are notoriously poor performers after a relatively short time. Checked yours lately? All it takes is a bad ground or a wire broken from driving through some brush.
Feb-03-2015 02:02 PM
spoon059 wrote:rbpru wrote:
I have seen data to show improved weight capacity for 3/4 and 1 ton trucks, but I have never seen data or advertisements that they will stop significantly faster than a 1/2 ton.
I also have not seen any data indicating they are less likely to rollovers. The bigger TVs may have bigger tires and a stouter suspension but you also have more rolling mass.
All TVs are designed to operate within certain parameters, how close to these limits or how much over you wish to go is nothing new.TomG2 wrote:
This has nothing to do with them unloaded, only when both are towing 7,000 pounds and the electric brakes on the trailer fail to perform perfectly. Which brakes will have more capacity? Those on the 10,000 gvwr pickup or on the 7,500 pound gvwr model? Take a look at them sometime.
I tend to bring these points up in these arguments and nobody ever has anything intelligent to offer after I post it.
I highly doubt that is true. I would love to see if someone has empirical data to support this claim. It just doesn't add up to me.
Yes, I agree that a properly equipped and set up heavier truck will always handle better than a properly equipped and set up lighter truck. I don't think anyone will disagree with that sentiment. Lots of posters here have made the switch to a heavier duty truck. Good for them. The fact of the matter is that a lot of people cannot afford or justify the cost of a heavier duty truck when a half ton is PERFECTLY CAPABLE of handling their needs.
I'm not justifying people who exceed their weights. However I cannot understand the argument from some people here that a half ton is only capable of handling 75-80% of its rated values... but a 3/4 ton is "just as good as a 1 ton, it just doesn't have the extra 2" spacer". On one hand the engineers and testing on the half tons is way too liberal and they aren't safe to those weights... but on the other hand the 3/4 ton testing is too conservative and the 1 ton testing is accurate.
Feb-03-2015 01:50 PM
Feb-03-2015 01:42 PM
PawPaw_n_Gram wrote:BubbaChris wrote:
I think the other side of the coin that hasn't been mentioned yet is the salesperson (TT or TV). They are very busy trying to close the deal and won't take the time to point out the real limitations.
I've had several salesmen over the years ask what I was planning to tow a TT / 5er with - and been told "You can't tow this trailer with that truck."
Feb-03-2015 01:40 PM
Feb-03-2015 01:32 PM
4X4Dodger wrote:TomG2 wrote:4X4Dodger wrote:
....snip.......... And until this is done please do not continue to claim that a 3/4 ton truck is by default SAFER that a 1/2 ton or an SUV. There are too many factors involved.
You really think that a half ton pickup with a "Tow rating" of 9,600 pounds is good for that or more? Maybe I read it wrong, but you seem to be saying that the ratings are lowered by the engineers and lawyers?
Yes I do and that is **almost** exactly what I am saying. I said that the ACTUAL DESIGN LOAD is at least 1.5 times higher than the Design SPEC. And that the Design spec is further DE-RATED by the legal department to the numbers you see published so they can have what I called "legal Headroom" in case they must defend their decisions in court.
All over the world I have seen much smaller vehicles than 1/2 ton Pick ups carrying/towing much larger loads on a daily work basis than what most Americans believe is even possible. With much smaller engines. Are the physics different? No. It's the legal system that is different.
And further, as I pointed out previously, there has never been any real world testing of what the actual limits are for any given truck/spec combination. Until then the numbers are really meaningless.
Feb-03-2015 01:14 PM
spoon059 wrote:
....SNIP.......
...SNIP......
Feb-03-2015 01:03 PM
Feb-03-2015 12:57 PM
