Oct-22-2017 09:11 PM
Nov-03-2017 12:21 PM
Oct-28-2017 08:47 AM
Oct-27-2017 07:39 AM
RCMAN46 wrote:JIMNLIN wrote:
In all those years and over 1.2 million miles on the road never saw or heard of a tube being crushed till I came on a RV website.
The axle tubes on current RV trailers can and have been crushed.
Mine was not crushed by a jack but a chuck hole on I 40 near Kingman Arizona.
Oct-27-2017 07:26 AM
Oct-27-2017 07:10 AM
Oct-24-2017 09:49 AM
RCMAN46 wrote:Okay, you've used all your Lynx Levelers to raise the frame, what do you use to support it now that you've got it up there?Old-Biscuit wrote:
Does anyone carry all that cribbing needed to jack trailer by frame when laying on the side of the HWY with a flat tire OR jack it under the axle tubes at spring perches :H
I do.
I have two bags of Lynx Levelers for leveling my trailer. More than enough to set my bottle jack on to raise trailer by the frame.
Oct-24-2017 08:19 AM
Wild Card wrote:
Lifting a trailer by 1 single point of the frame is a no no. Ask Lippert. You must lift for and aft of the spring hangers. so thats 2 jacks and enough cribbing for each.
So if your not doing it that way, your still doing it wrong
Oct-24-2017 08:09 AM
Oct-24-2017 07:54 AM
Oct-24-2017 06:41 AM
Oct-24-2017 02:33 AM
N-Trouble wrote:I'm only lifting one wheel off the ground just high enough to remove it. It's compressing that one spring. If I keep jacking enough to raise the other wheel then yes, it will be 50%.2112 wrote:
I lift one wheel at a time at the perch with a 2 ton floor jack. It's only lifting 25% of total weight minus hitch weight. For my setup that's ~2080lbs per wheel on my double axle.
A triple axle would be 16.66% of total weight minus hitch weight.
Wouldn’t it be 50% of total - tongue? When you lift one wheel to raise the other off the ground your carrying the weight of both axles on that side.
Oct-23-2017 10:11 PM
Oct-23-2017 10:05 PM
Oct-23-2017 08:50 PM
