30 foot run of sewer hose--downhill?
coolmom42
Looks like my closest dump location (into a sewer cleanout) at home is going to be about 30 feet horizontally and about 4-5 feet (luckily) downhill from the RV.
Is it feasible to run that much Rhino hose, or similar hose, that far? Would I be better off with some sort of rigid pipe that can be disassembled for storage?
I really don't want to buy a macerator pump, and doesn't seem it would be necessary.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
33 REPLIES 33
jdc1
Dick_B wrote:
The perfect slope is:
For 4-inch PVC piping and a building sewer less than 50 feet long, the minimum slope is 1 inch in 8 feet, or 1/8-inch per foot, and the maximum is 1/4-inch per foot.
This per an internet search.
This is correct (40 years as a contractor). The waste needs water to float on to travel.
cavie
Macerator pump stores much easier.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
Horsedoc
beaker has a good point. You don't want the water outrunning the load it is carrying
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
JRscooby
When installing sewer lines we said we wanted it to flow or drop. When got too close to surface install vertical, then flow again.
For dumping a RV, you should have a slug of water behind any solids. OTOH, the ribs in a sewer hose would change the flow, and I'm not smart enough to know if better or worse.
I think if I was looking at OP's problem I would use PCV, and build a above ground system that could be set in place, used, flushed then stored
wa8yxm
dedmiston wrote:
You'll be fine. It literally flows downhill.
You're good.
Nomination for best answer in the thread. Absolutely the best.
And to the OP I agree with Dedmiston so long as it is down hill does not matter if it's 5-10-20-30-50 feet SO LONG AS YOU HAVE ENOUGH HOSE.
I have about 50' of 3" (Multiple sections) and then the macerator with 50' of 3/4 " and yes I've found a need for all of it.
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
TenOC
No problem, but I would use white PVC 3" (?) sewer pipe. It will drain better and last longer and cost much less $$$. You can get an adapter to attach the PVC pipe directly to your RV. No need to glue the pipe together. A press fit will work fine.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Grit_dog
Navigator
Navigator
You may wish to research septic systems, mostly about pitch of the run. Too steep will leave solids behind. Probably 2 or 3 half tank flushes would help.
Not an issue in this case. This is not a traditional sewer line. The rush of water will push everything down.
Presuming the OP is talking about traditional RV dumping.
coolmom42
Old-Biscuit wrote:
After dumping you Will need to walk the hose to move all contents down/out of hose then flow clean water thru it and walk it again.
I have THREE 15' sections and have had to use it a few times
Walking/rinsing WORKS
Thanks. I've seen some sites where that much hose would be needed. May just pile it in a bin and take it all with me anyway. At least the Rhino hose collapses nicely!
coolmom42
I'm a little paranoid about flushing anyway, so will be doing that for sure. Good point.
Old-Biscuit
SAR_Tracker
The Plumbers Lament:
It flows downhill, and payday is on Friday!
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
Sjm9911
On a recent teip to hersey pa i needed a 30 foot to get to the sewer on the site. The sewer was at the end of the site. You'll be fine. Flush it as said. Good to go.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
Beaker
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
coolmom42
BB_TX wrote:
15โ€™ Rhino with a 15โ€™ extension would work fine for that. That much downhill would easily allow water and solids to flow out.
That's what I was hoping people would tell me.
I have one 15' section of Rhino that the previous owner left in the RV. I will have to measure the distance exactly, but obviously will need at least one more. If the ground is dry I can drive closer, but if we've had lots of rain I will have to stay on the concrete, which is farther away.
Thanks!
