I would leave mine on at 105 volts.
Actually I would be plugging in my voltage booster if it was running and less than 110 volts. But I have a 12 volt booster, you do not.
Look into buying a 'autoformer'. It will boost the voltage by 3% all the time, and boost it by 12% when the input voltage is low, automatically!
You might try plugging in to the same receptacle as the washing machine. It should be on a dedicated 20 amp circuit, and they have a second dedicated 20 amp circuit for the dryer. If they have a electric dryer, that one is free to use by the RV.
Actually if they have a 4 wire dryer, you can built a adapter. Buy a 4 wire dryer cord at Home Depot and wire it to a surface mount 50 amp stove receptacle. Then you can unplug the electric dryer, plug into the 30 amp plug, and plug a 50 amp RV directly into the stove receptacle. They are the same 120/240 50 amp plugs. If you do not already have a 50 to 30 amp adapter, you should consider buying one. You might run into a 50 amp only park someday, or more likely find that you are in a RV park with a broken or weak 30 amp receptacle, and using your adapter will prevent overheating the cord end on your RV.
If you constantly monitor the voltage in your RV, (say with a Kill-A-Watt) that stays plugged into a receptacle, you will find that many 30 amp RV parks have low voltage. Yet parks that have 30 and 50 amp plugs have higher voltage due to larger wires going to each site. Many times they wire about 10 units to a 200 amp circuit breaker! That larger wire does not drop wire like a 30 amp site that might be 200' away from the circuit breaker panel, and only have small #10 wiring.
Good luck, Have fun camping!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
