โJul-20-2013 07:01 AM
โJul-21-2013 07:21 PM
rockhillmanor wrote:
Maybe you'all don't get why most of us leave just one tank on. Until they put a indicator lever INSIDE the RV it is more prudent to leave one tank on so that you 'know' when it is switching over to the other and can plan for when you will need to get the tanks refilled.
But you guys keep going out every hour and checking that lever and on that cold day you forget to check and run out of both tanks, have not heat and can't get them refilled, get back to us! :B
โJul-21-2013 12:15 PM
โJul-21-2013 10:22 AM
smkettner wrote:I agree.... How simple is that?
Both open for me. I like automatic stuff and using it as designed. Have never run out of propane because it tells when a bottle is empty.
โJul-21-2013 09:40 AM
โJul-21-2013 09:30 AM
โJul-21-2013 08:53 AM
exeter_acres wrote:Atlee wrote:
What is unsafe about having both cylinders open at the same time?RamTX wrote:
Just for safety purposes, I use one tank at a time, i.e. keep the cylinder valve closed on the tank not in use.
my question as well
โJul-21-2013 08:02 AM
โJul-21-2013 07:33 AM
camperpaul wrote:Dave H M wrote:
I really do not get the auto run out of propane deal.
When one tank gets empty the indicator shows red and it automatically switches over.
Soooooooooo, if the indicator is red the lever is pointing to an empty tank.
:S
I seem to think that a lot of folks do not know how to make good use of the auto change over. :h
X 2
โJul-20-2013 08:06 PM
WoodGlue wrote:
Propane. Who here leaves open both tanks and let's the switch over do it's job and who only uses one tank at a time, and waits until it runs out to switch over?
I always leave both tanks open and let it do its thing.
WoodGlue
โJul-20-2013 06:33 PM
โJul-20-2013 06:16 PM
โJul-20-2013 04:30 PM
โJul-20-2013 04:16 PM
โJul-20-2013 11:13 AM
:S
