โMay-27-2014 05:40 AM
โMay-27-2014 03:56 PM
โMay-27-2014 03:49 PM
โMay-27-2014 03:18 PM
wa8yxm wrote:
The rule I used when I was trailering.
I used wood 2x tire width (Still do) to get to within .75 inches of level (NOTE 2" lumber is 1.5" thick) then I used the jacks for the last little bit.. MOST trailers this should work.
If you want to take a bit of stress off. You could also carry a 1x tire width That gets you to 3/8's of an inch (actually both 3/4 and 3/8 of an inch are close enough to say "Forget it".
โMay-27-2014 03:04 PM
bid_time wrote:bob213 wrote:Really? How'd you come to that conclusion?
The less you have to extend the stabilizers the more stable they will be.
โMay-27-2014 02:12 PM
โMay-27-2014 11:22 AM
Fastfwd75 wrote:
From Skyline manual:
"5. Lower stabilizer jacks, placing wood block under foot as necessary, until they make firm con- tact with ground โ Do Not Overtighten or try to lift trailer except for small amount needed to level."
โMay-27-2014 10:52 AM
Fastfwd75 wrote:The leveling of the trailer is about how much it is out of level for the width dimension of 8' (or so). You don't have to be that much off of level that a 1 1/2" board under the tires on one side bring it back to level.
I'll get a set of levelling blocks. I wanted to make sure I don't spend and carry things I don't need. Those are cheap and seem much easier than bringing a collection of wood planks and trying to stack them as a ramp to drive onto.
Thanks
โMay-27-2014 10:25 AM
โMay-27-2014 09:42 AM
โMay-27-2014 09:32 AM
โMay-27-2014 06:40 AM
โMay-27-2014 06:38 AM
Look up the specs on your scissor jacks. Some are rated at a certified 6500 lb load capacity. Some have feet that stabilize only and carry no load. I use all four of my scissor jacks to level a inch or two without any problems.
โMay-27-2014 06:36 AM
โMay-27-2014 06:33 AM
