DEF - Usage
Jhurk
Just on my maiden voyage with my 2014 Ram 3500 Diesel pulling 13,500lb 2009 Cardinal 34'. Pulls like a dream very nice to drive however after 1,000 miles I have gone through 1/2 tank of def, 2.5 gals. Normal,driving I was told I would get 5,000 miles to 5 gals of def. I know pulling under load you use a lot more but I was shocked when I looked at the guage? Is this normal? I'm going to the dealer to inquire and buy so,e more!
Jim Hurkett Chilliwack BC
2014 Dodge Ram 3500 Limited SWA
2009 Cardinal 30 TS
37 REPLIES 37
Searching_Ut
Keeping with the Snipe remarks, my 5er has a "Hot" water heater....
I checked with other Ram owners at work, and the general consensus is 500 to 700 miles to the gallon when towing. The Chevy guys report a little better.
As for the advantages of DEF, I only mentioned "Gas" mileage (input snipe here) in my earlier post. The DEF utilizing Rams also go twice as long between oil changes, with downside being the truck doesn't "make oil", so I'm now not recycling as much, and hence not doing my part for the environment. Fuel dilution due to Re-gen blow by and excess carbon build up from high EGR was fairly significant on my 2011.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
spoon059
cbshoestring wrote:
You would also be surprised how many people redundantly say "fluid" after using the term (initials) D.E.F. (Diesel Exhaust FLUID).
Ok...that was a snipe....I deserve troll status.
On a related note... VIN number. That is all.
2015 Ram CTD
2015 Jayco 29QBS
tomman58
I've said it more than once. FILL UP DEF AT A TRUCK STOP. Generally when my def is low I get a warning message to fill up in the next 1000 miles. CAN DO!!!! At the pump it goes for $2.78 a gallon. It is fresh (this stuff has a shelf life of 2 years max) No big deal, ever!
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
cbshoestring
Wild Card wrote:
Dont really find it funny when someone gets a lesson on how things work. You really have no idea how many people buy these trucks and think that DEF fluid is used to clean the DPF in the regen process.
ktmrfs
tinner12002 wrote:
That's probably pretty close to what mine does when towing. Empty non towing it hardly uses any but yes, when towing they use a bit more. Normal usage in my opinion.
normal useage is around 1 gallon of DEF for 100 gallons of fuel. this is very close to what I use as well. so your useage seems on the high side, at 10mpg in 1,000 miles that is 100 gallons, so about 1 gallon of def. 2.5 gallons seems high. but the key is to track it accurately over say 5,000 or 10,000 miles.
2011 Keystone Outback 295RE
tinner12002
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
Wild_Card
1jeep wrote:
N-Trouble wrote:
1jeep wrote:
I had an 08 diesel that didn't use DEF, it would inject fuel into the DPF, when that regen would happen your MPG turned into how many gallons per mile!
DEF trucks still inject diesel into the exhaust/DPF during regen. DEF is not a replacement for diesel being used during the regen process. Time to do a little homework on what DEF does and how its used.
No need I just get in and drive the truck, add stuff as needed.
BTW, I know it still uses fuel in the DPF, but I guess I should have reread my statement before posting to all these engineers up here...lol
You dont have to be an Engineer...you dont even have to be the head cashier at Walmart.
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
1jeep
2016 Ford F350 crew cab dually 6.7 platinum with heavy tow and 4:30 gears
2015 Carbon 327 with a BMW k1600 and Canam 1k inside
christopherglen
The DEF is only to reduce NOX emissions. Pre DEF systems did this by delaying injection to reduce peak pressures, and pumping a lot of exhaust back into the engine with the EGR. The DEF and SCR allow lower EGR flows, and more advanced timing, which puts the peak pressure where it makes more power, not less NOX. The DEF system then treats the exhaust to break down most of the NOX, to be below EPS levels. Advancing timing also helps with soot production, as the fuel has longer to burn in high temp / high pressure of the engine, before being shot out into the relatively low pressure exhaust system. Remember, more power for the same fuel is the same as less fuel for the same power.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Bedlam
Moderator
Moderator
DEF allows the engine to run hotter and produce less particulates. The downside of this is increased NOx which is handled by the DEF after treatment. Since less particulates are being collected in the DPF, regens are less often with a DEF equipped engine.
N-Trouble
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
naturist
Jhurk wrote:
As for,the brand of def the dealer says that some cheap brands "Walmart can cause damage. There have been comments on Ram forum that users of Walmart def have caused problems, vehicle shut down tow to dealer and had to have system flushed out? I'll stay with molar for now.
There have been reports of folks taking advantage of Wally's too-generous return policy by buying DEF, pouring it into their truck, refilling the jug with tap water, and returning for refund. Wally fails to check anti-tamper seal for breakage, and simply reshelves. The wise grasshopper checks the seal before picking up the jug.
Jhurk
I checked ar the Dodge dealer and they stated it was on the high side of normal but still within acceptable range with respect to which brand of def to use they stated that as long as the def was fresh no older than one year all brands ok. However stores like Walmart have had def on shelf for long period and no good. Get from high volume locations.
2009 Cardinal 30 TS
ktmrfs
Jhurk wrote:
I was traveling at 63 mph rpm around 1500. I was shocked when I first looked at def guage and it was at 3/4 wow that was after 400-500 miles. I guess from comments that maybe normal I'll see what dealer says today. As for,the brand of def the dealer says that some cheap brands "Walmart can cause damage. There have been comments on Ram forum that users of Walmart def have caused problems, vehicle shut down tow to dealer and had to have system flushed out? I'll stay with molar for now.
all DEF meets the exact same spec's and defined formula. and normal usage should be about 1 gallon of DEF for each 100 gallons of fuel.
