Diesel Additive
filrupmark
What type of diesel additive would be good for keeping injectors clean,moisture control and maybe added cetane & lubricity. What do you use.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
30 REPLIES 30
camperpaul
I use Howe's Diesel Treatment
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
Raften
Add some biodiesel.
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
john_bet
My book says not needed so I don't. So far so good in 10+ years and 162+k and counting. JME.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
Halmfamily
I use Diesel Keen in the winter as my truck sits for weeks without being used. Summer nothing.
Sorry double post.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
Halmfamily
NHIrish
Trouble maker! You opened a can of worms with this...most of the answers you get will be preference based on nothing but opinion. Good luck. The folks that make it won't give you straight answers, and the last study done (Spicer) is getting old.
FWIW...you probably are better off with the right additive. As best as I can determine, the Bosch injectors are designed for european spec fuel...not the US spec...which has less lubrication. Do your research and then feel your way through....best you're gonna do.
The biggest no-no is alcohol based fuel additives and so called emulsifiers.
If it helps, I used Stanadyne performance formula for years, but just started using Opti-lube summer +. Stanadyne was fine but a little light in the lubricity department. Not sure about Opti lube summer plus...hoping for a new study.
2016 Heartland Bighorn 3270RS
2010 Carriage Cameo 32-FwS
2008 Carriage Cameo
2006 Keystone Cougar
2005 Keystone Zeppelin
1999 Coachmen Catalina
2017 Ford F350 Powerstroke
Curt Q25
Diplomacy is the art of saying 'Nice doggie' until you can find a rock
:W
Winged_One
gbopp wrote:
SeaFoam
Holy price point Batman. 1oz per gallon. At wallyworld $9 a bottle that's $20 a fill up.
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
msiminoff
You didn't mention the year/make/model of your engine… which could affect your choice of additive (if any).
I add Power Service Diesel Kleen to every tank for my personal truck and also in my company's fleet of (six) diesel vehicles.
Sliver in summer. White in winter.
Cheers,
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
jason4598
Stanadyne
MinnCamper
Diesel-Kleen. Sliver in summer. White in winter.
Old-Biscuit
Nothing in my '07 5.9L Cummins
For your '04 F250 6.0?
ChooChooMan74
Opti-lube XDP
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
gbopp
yrusoslo
Seafoam
MEXICOWANDERER
I used the stuff available at Wal-Mart sold in white square plastic bottles. Forgot the name but the bottles are white with black and red print. With the garbage they are peddling for diesel now, the stuff may help fuel mileage and driveability. I sure wouldn't pay for an additive unless it did something concrete.
