May-21-2018 03:42 PM
May-22-2018 04:50 PM
May-22-2018 03:05 PM
BenK wrote:
My setup image and can be done by myself with no helper
Use the old pad and do NOT remove it just yet
Turn a bottle of brake fluid upside down in the MC reservoir with the cap removed
Large C-Clamp on the caliper piston and other side. Open the bleeder screw that has a hose to a catch jug
Turn the C-Clamp to push out the old fluid through the bleed screw and into the catch jug
Close the bleeder screw and remove the C-Clamp...or loosen it enough to allow this:
Go into the drivers seat and pump the brake pedal (the engine can be on but I prefer off) until it is firm
Back the caliper and open the bleeder screw and tighten the C-Clamp to force out the fluid in the caliper
Repeat going up to the drivers seat and pump the brake pedal
This is repeated about 3-4 times, dependent on how large your system is
All new fluid and the last time compressing the C-Clamp...remove the old pads and insert the new pads
Reassembly and that corner is done
Repeat on other corners
I can bleed my Sub's front disc brakes in about 20-30 minutes and the time to bring out the tools and return takes about another 20-30 minutes
May-22-2018 02:42 PM
Grit dog wrote:
If you question the shop, then question them. You don’t know if they’re feeding you a line or not and we don’t know how you drove for the last 60kmiles.
However 60k on a half ton does sound about time unless you drive with eggs on the pedals!
Low dust, get ceramic, 12V98 is wrong. Good ceramics will stop as well or better than most OE pads, last jsut as long, don’t destroy rotors despite the rumors and VERY LOW DUST!
Power stops we’re reccomended recently. They cost less than the boutique brands.
I’m running EBC pads on the pickup and one car and side by side, they are about 80?% less brake dust than organics or semis.
I’m sure Akebono and Hawk are also very high quality.
And to the ceramic brake haters, sit down before you read this......some OEs use them now too.....
Now gat out of your rocking chair and go yell at someone to get off your lawn!
May-22-2018 09:46 AM
May-22-2018 09:43 AM
May-22-2018 08:24 AM
May-22-2018 06:38 AM
theoldwizard1 wrote:riven1950 wrote:
OP here: Thanks for all the info folks. I used to do my own brakes way back when I was young. But that was in the day of drum brakes, never messed with disc brakes, and don't really want to.
I have been doing my own brake jobs for about 40 years. I can only remember doing 1 or 2 vehicles with front drum brakes !
May-22-2018 06:32 AM
May-22-2018 06:14 AM
May-22-2018 05:10 AM
May-22-2018 04:40 AM
May-21-2018 11:24 PM
May-21-2018 07:13 PM
3-Rear brakes are still ok they say, although getting close. Any reason to do both at same time other than convenience?
Hard to believe that rears are "close". Most vehicles the rear shoes/pads "rot" before they wear out.
May-21-2018 06:55 PM
May-21-2018 06:36 PM
