Can a tire explode from Over-inflation?
BurbMan
DW took her car into the body shop this morning...again...rear ended in the rain while stopped at a light...drivers in this town are terrible, but I digress....
So she gets a min-van rental from one of the biggest car rental companies. Lunchtime, she says "the TPMS indicator is on, one of the tires is probably low, can you put some air in? I figure sure, easy enough. Pull it in the garage, and check the door jamb...36 psi called for at each corner. (Impressive 6100 lb GVWR too...)
So I grab the gauge and hit the LF...57psi :E 21 pounds over!! Must be a fluke, so I check the LR...55psi :E Then on to the RR...53psi :E Finally on to the RF which is at 19psi and has a nail in it...easy enough to get to, so I was able to plug it right on the car. All tires at 36 psi and the flat fixed.
Seriously, for the life of me I can't figure out why they overinflated the tires by 20 psi...no telling how long they have been like that either...is there a point where a tire could blow from being OVER inflated??
25 REPLIES 25
Francesca_Knowl
BurbMan wrote:
I am certainly not going to tell them I plugged the tire...so not sure how they could attach liability to me. Not to mention the fact that I am confident in my work, so I don't think there would be an issue to start with. If anything I mitigated liability by setting the tires pressures to what they should have been.
May I suggest that you ought to tell them? I think they have a right to know, especially if the repair consisted only of a plug. Since you say you patched the tire right on the car, is it fair to assume that a plug-from-the-exterior is what the repair consits of? I think that's considered sufficient for a temporary repair, but it's my understanding that the correct permanent solution is plug AND patch from the tire interior.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
chevor
I like my TST tire monitor system. I can see not only tire psi but temperature while traveling. Tires at 75 psi cold in the morning before moving will be 90 psi and at temps 90 to 110 degrees while traveling. They will vary with deferences depending on outside weather, day and night.
Typically a higher starting cold pressure with cause the tire to vary less while traveling.
Jarlaxle
transamz9 wrote:
You guys that are plugging your tires from the outside do know that when you do this to a speed rated tire that you no longer have a speed rated tire right? This is why you have spares. Take the tire to a shop that properly repairs the tires from the inside. 😉
BenK, I did the split rims when I worked for Goodyear. Loaded fire trucks are the worse there is. LOL
Don't imagine an 11.00-24 on an elderly Mack concrete mixer is much fun, either!
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. 😞
Current rig:
1992 International Genesis school bus conversion
JIMNLIN
This from Tireman9 tire blog (Roger Marble...rvtiresafety.com)
"Tire Maximum Pressure
Many times people incorrectly think the pressure molded on the tire sidewall to be the maximum tire pressure a tire can tolerate, when in reality you should consider it the minimum pressure needed to carry the load indicated
Tire companies design and test their tires to tolerate pressures much higher than the number molded on the sidewall. For regular passenger tires it is probably close to or above 150psi. Light truck tires will probably be a bit higher and truck tires higher yet. In almost all cases I am aware of, there is a good possibility that the wheel might fail from high pressure before the tire simply explodes from high pressure."
Interesting......
p220sigman
YOu likely couldn't get enough pressure in to physically blow up the tire with a consumer air compressor and as has been said, the bead will likely go before the tire itself.
I saw a split rim let go at a tire store when I was getting work done on a company car. Fortunately, they were inflating in a steel cage so no damage to people, but the tire jockey had somehow run the air hose between one of the steel bars and the tire and when it let go, it severed the hose just like it had been cut with a knife.
BurbMan
majorgator wrote:
I'm still trying to figure why you're plugging a rental vehicle tire...?? Sure, its simple enough, but this little word called "liability" comes to mind.
Time is money...she is a realtor and had places to be other than waiting at the rental co for them to plug a tire. Van has 26k miles on it, I am certainly not going to tell them I plugged the tire...so not sure how they could attach liability to me. Not to mention the fact that I am confident in my work, so I don't think there would be an issue to start with. If anything I mitigated liability by setting the tires pressures to what they should have been.
DW drove the van about 3 miles back to the house and it was parked before I got to it at noon, so tires were cool. Sidewall says 44 psi MAX, so clearly somebody wasn't paying attention.
T&P thanks for the info, I wasn't sure what the "limit" was for inflating a tire before it went BOOM.
Turtle_n_Peeps
No, not under normal conditions and pressures.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
transamz9
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
BenK
Rare, but it can happen....depends on lots of conditions
Worked as a tire monkey through college
Owner wouldn't let me work on split rim...too dangerous and his shop did have guy go to the hospital from a split rim letting go
I was in the show room showing a customer another set of tires after finding out his truck required LT's and the sales Guy sold him P's
One of the other guys was working on another customers about five bays away...setting a bead had that P class tire blow up...the front bay window almost blew out...the guy on the tire stand was knocked out...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
RoyJ
To actually burst a tire from pressure alone, would take tremendous pressure. Stunt drivers that balance a car on 2 wheels routinely pump 100+ psi into P-rated tires.
I've read about tests on commercial (110psi) tires, and it took well over 500 psi before busting. However, you're likely to experience rim damage before that.
I'd be more worried about uneven treadwear, and lack of traction than tire burst. Most tire failures occur due to heat - either by an overloaded Explorer running 15 psi, or a Corvette doing sustained 180 mph on old tires.
darsben
deereone wrote:
Very unlikely a good tire will explode from being over inflated. But they are most likely to blow off at the bead before the tire will give out. I have seen that happen. For as long as I can remember truck tires have been required to be in a steel cage when being inflated. Older truck tires that had the steel ring (name escapes me right now) killed many people while inflating them.
They were split rims. Had them on an old Winnie Chieftan
Traveling with my best friend my wife!
N-Trouble
Terryallan wrote:
I wonder. How long had she been driving the van? A hot tire will have a much higher psi than a cold tire. so if the tire were at 35 psi cold. Could they be at 55 psi hot???
We are told to check the tire cold. Airing up a hot tire to the cold psi, will make it have low psi.
Just a thought.
PSI wont go up by 20 between cold/hot. Maybe 5-6PSI at best.
Max PSI stated on tires is always a COLD figure.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Terryallan
Just a thought.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
BurbMan
A few years ago I bought this Safety Seal tire repair kit. Makes a fast, permanent repair, and much higher qulaity than the parts-store tire plug kits.
Click image for webpage:
Also note the instructions.
