โDec-20-2015 07:15 AM
โDec-20-2015 09:47 PM
โDec-20-2015 09:24 PM
โDec-20-2015 08:20 PM
โDec-20-2015 05:40 PM
โDec-20-2015 02:52 PM
Bowti wrote:
Save yourself a lot of money and grief and buy hard sided kayaks or a canoe. One problem with inflatables besides puncture, is they are hard to regulate as far as air pressure. Leave them in the sun and you exceed recommended pressure, put them in cold water and they become under inflated and float like a anchor. Forget about covering any distance with them, as they push the water instead of gliding over the top. If you want to float down a river fine, but don't try going against any current. Things are much better with the higher priced ones, but I think you would be much happier with one that is more versatile.
As for carrying, this seem to be very popular way. Loading and unloading is easy.
โDec-20-2015 02:49 PM
โDec-20-2015 12:00 PM
โDec-20-2015 11:48 AM
โDec-20-2015 10:09 AM
Twomed wrote:
JMHO BUT... if do like "goducks" above and buy cheap you are destined to be disappointed. My five year old Advanced Elements is still just fine. Faded a little, scratches on the bottom from oysters and rocks, but still many years left in it.
โDec-20-2015 09:01 AM
aguablanco wrote:
We are whitewater rafters and inflatable kayakers (IK) and we have several rafts and IK's. Generally, we wash them with laundry soap before storage and try to let them dry because we may store them for months before the next trip. That should not be what you have to do. As stated earlier, dry as much as possible and roll it up. Better to roll than fold as it doesn't put creases in the fabric. When you get to the next destination inflate and let dry as much as possible. We also use 303 protectant to minimize UV degradation. Never use Armorall as it penetrates the fabric and makes patching very difficult. They make self bailing models that will drain any accumulated water and allow you to sit in relatively dry comfort. There are also rubber grommets that fit on the paddle shafts that help keep the water off your hands and out of the boat.Depending on your needs, you can expect to pay anywhere from $100 up to $1500. If I can answer any questions please feel free to contact me.
RichH
โDec-20-2015 08:15 AM
โDec-20-2015 08:14 AM
โDec-20-2015 08:07 AM
Artum Snowbird wrote:
We have this model Advanced Elements 1007 and really like it.
I use a battery powered air mattress inflater to get most of the air in, and then have to use the more high powered manual pump to harden it up. I also have converted the wheels and frame from an old fertilizer spreader by removing the bucket and gears, and we tie the kayak onto that and with only a little weight on the bow, we pull it to the lake, then strap the carrying framework onto the back while we paddle.
So, yes, we like to dry it out. Our model comes apart into floor, tubes, and outer canvas. It does take some time to dry it out, but it's so fun to paddle about on nice days. We usually spread the parts over a picnic table or even a rope between trees, then re-assemble it before folding it up. If we stay for a few days it just slips underneath the rig on a 9 by 12 tarp diagonally.
โDec-20-2015 08:04 AM
โDec-20-2015 07:58 AM
