Does the Banks ram cold air intake really help
panamacamper1
I recently purchased an 06 ram 2500 mega diesel. The rear suspension was beefed up with what I think is called helper springs. So, I assume this makes the rear end a 3500? That was the only mod when I bought her.
original post question is the Banks cold air system is 410.00
Would getting this set up show an improved mpg? I ask those of you who have this installed. I am also looking at straight piping the exhaust unless someone has a recommened set up. I would also like to get the ecu done but i am still learning and doing research on a good set up.
30 REPLIES 30
JIMNLIN
catfishmontana wrote:
I saw about a 150 degree drop in EGT's in my 2006 by switching from the stock setup to an aftermarket cold air intake.
Same here when towing up to 16k when I installed the AFE pro 7 to my brand new '03 Dodge/Cummins 305/555 HO truck. Non towing didn't show much difference.
I Didn't install it to gain mpg but help in keeping EGTs down when hauling.
I have a Westach dual guage EGT/boost. Great diagnostic tool.
Slowmover
The stock airbox is good to 450RWHP. Aftermarket is also unlikely to have an air filter as good as the deep MOPAR piece.
The very latest CTD has specialized hot and cold intakes; switches from one to another depending on conditions. That would be a sweet retrofit.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE RAM 2WD 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 11-cpm solo, 17-cpm towing fuel cost
Cummins12V98
C Schomer wrote:
My stock 03 muffler was terrible. It was so choked, it hissed like I had a smashed tailpipe, when towing. You already have 4" and that is enough. A 4" straight thru muffler is all I would do to your exh. The air intake stuff isn't worth the money. Do a search on the home depot CAI mod. Guys cut a hole in the bottom of the air filter box and use HD cheap parts to get more cold air from down lower. It's also good to get more air in the bottom of the box when you put in the newer deeper filters. Gauges (at least a pyro) are nice but not necessary til you add fuel. It's scary how hot some of the stock diesels run and you will be helping the egt a little with 2 cheap mods... muffler and the hd cai. I put a pre-turbo pyro in a fiends CTD and it was going over 1400. He took it to Cummins to see why it ran such high egt and they moved the probe to after the turbo and told him... there it's fixed, quit worrying about it! Craig
Pre turbo is exactly where it should stay.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ib516
I have had no issues with my set up, and it has a nice power boost.
4" MBRP exhaust with straight through muffler, no CAT, no resonator.
Hypertech programmer set on stage 2 (middle).
The Diablosport Predator tuner I also have (picked up used out of the local classifieds for $60) gives WAY more power, but the truck runs much smoother on the Hypertech.
As a side note, gauges give high marks in the LCF (look cool factor), but are $$ and not required. You can add a $169 Scangauge2 and monitor trans temp digitally - among other things.
The Hypertech tuning is safe - no EGT gauge required. It is the only tuner I would run without monitoring EGT. I know the Smarty Jr is also advertised as EGT "safe" - and that could be, I just don't have any direct experience with it.
Whatever you choose - keep us updated!
Oh, BTW, Diesel Power magazine did dyno tests with the stock cold air intake and several afetrmarket ones. None made any more than 1 or 2 hp over stock on a stock truck. COLD AIR INTAKE DYNO TESTING
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
C_Schomer
srt20
My 05 muffler was defiantly not straight thru.
I have a setup I cam across on a diesel forum, I forget the name of it, but it's basically a 5" turbo back with a resonator that goes under the cab. It's actually quieter in the cab than the factory setup was but a little louder at the tip. Not "look at me loud" though.
The resonator is not a glass pack type design, it is a smaller straight thru center, with a auger type outer design. It's the same size as the rest of the pipe, 5".
No cat, no muffler. No emissions here were I live.
Stock muffler rusted out, otherwise I probably would have just left it on.
mountainsam
Actually I do not have gauges but that is the next purchase.
2017 Thor Gemini 23TR w/ 3.2 Power Stroke turbo diesel
2014 Ram 6.7 Cummins Turbo Diesel Crew Cab, Long Bed 4X4 6 Speed Auto (sold)
2013 Rockwood Signature 8281 WS w/Sidewinder Pin (sold)
DW and Sofie our Black Lab /Boxer and Phoebe our Schnoodle
ksss
mountainsam wrote:
I just paid 2100 bucks to reinstall a cat. My 05 was purchased in MO at one year old and with a straight pipe. Sounded great at first but soon got irritating as heck. We added the muffler back but not the cat. In 2013 we moved to CA. To license the truck I was required to install a new cat. Not a cat but a new one. CA. would not accept a used one. Big problem. For the 05 Cummins I was told by the dealer that there were five new cats in the country. Dodge had to get involved to ship a cat from Ohio to CA. So if you decide to streighten out the exhaust hang on to the parts. You may need them some day. BTW. With streight pipe we got 21 - 22 mph on the highway running 2000 rpm. With the cat and muffler I get 20 - 21.
Are your EGT's higher with the CAT and muffler?
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
mountainsam
I just paid 2100 bucks to reinstall a cat. My 05 was purchased in MO at one year old and with a straight pipe. Sounded great at first but soon got irritating as heck. We added the muffler back but not the cat. In 2013 we moved to CA. To license the truck I was required to install a new cat. Not a cat but a new one. CA. would not accept a used one. Big problem. For the 05 Cummins I was told by the dealer that there were five new cats in the country. Dodge had to get involved to ship a cat from Ohio to CA. So if you decide to streighten out the exhaust hang on to the parts. You may need them some day. BTW. With streight pipe we got 21 - 22 mpg on the highway running 2000 rpm. With the cat and muffler I get 20 - 21.
Teebucket1313
I know your not asking about gas vehicle...but I would like to get my 2 cents in....I had a 2008 National RV with the F53, V 10 and I had the Banks Power System install by CW.....it did add a little more power and 2 tenths of a gallon mileage increase. I don't remember the total cost....over $3000.00. My opinion is I would save the money. It just made the motorhome sound like a hot rod when you step on the gas. Intake was so load when you stepped on it you couldn't even talk over it.
Happy Camping.
Bye Dennis
Dennis & Sheri
2007 Travel Supreme
Good Sam Life Time Members
FMCA member F399328
2021 RAM 1500 4X4
campigloo
I had a 2000 7.3 and gradually installed a GitKit from Banks. I couldn't see any significant change with just the fancy intake. But put the whole kit in there and it was like adding an extra engine! Worth the money?, I thought so, but you have to pull a lot to justify it IMO.
transamz9
DirtyOil wrote:
Really guys? Really?
Have ya even looked at the OEM muffler on an 05 or as the OP has 06?
Its straight through!! Its a bloody resonator!! Same kinda muffle ya see on Harleys... straight through resonator some packed more with noise reduction then others. the cat is like a tube and shell boiler there's yer restriction!! Hard to get a straight linear pipe from the turbo out to the tail pipe!! Straight pipe is cat delete, remove the cat install "straight" piece of tubing in place of the discarded cat! OEM muffler is straight through, unlike some car mufflers which have the inlet and outlet kitty corner from each other. Those are not straight through, they have baffles to direct the flow to aid in producing some back pressure as required by gas engines! Diesel engine is like an air compressor air in - air out...install a 5" straight pipe (cat delete) any "muffler" resonator yer ole heart can take and install a Smarty Jr. and tell the rest to suck an egg!! ๐Ÿ˜›
Well I guess someone at the factory must have put the wrong one on mine and someone must have stuffed something in this one so you couldn't see threw it.......
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
ScottG
I have indeed seen the insides of an 06 CTD muffler and it is NOT straight through. Take another look and you'll also see it's in and out are offset.
DirtyOil
2013 RAM 3500 CTD Crew 4x4 Laramie
2014 Sprinter Copper Canyon 269FWRLS
GUTS GLORY RAM
