Oct-08-2016 07:47 AM
Oct-10-2016 07:58 AM
4x4ord wrote:
I tend to load er up and go. If the truck acts overloaded I take it easy. In Alberta we are supposed to be mindful of our tire ratings.....axle ratings are enforced on big trucks next but disrespecting a vehicles payload, which is derived from the GVWR doesn't have much consequence as far as I know.
Oct-09-2016 07:36 PM
4x4ord - yer correct - an AB scale officer confirmed my SRW 3500 on 265mm tires would be legal at 265 x 10kg/mm of x 2 tires = 5300kg per axle OR the maximum load rating/psi of the tires whichever is less. In addition it is an offence to operate a vehicle that is "unsafely loaded." DOT has discretion to weigh any vehicle that appears to be unsafely loaded.
Would this truck be considered "unsafely loaded" as it cruised by a DOT patrol 10 mins before this happened?
Oct-09-2016 06:17 PM
Oct-09-2016 05:18 PM
Nate1979 wrote:
GVWR - curb weight = payload for your truck as loaded.
Oct-09-2016 05:12 PM
Oct-09-2016 01:48 PM
Oct-09-2016 01:25 PM
MitchF150 wrote:
(the last time I weighed #150, I couldn't even drive yet!)
Mitch
Oct-09-2016 12:38 PM
Oct-09-2016 11:36 AM
rhagfo wrote:
Yep, Old-Biscuit nailed it. In my opinion the only real use for the yellow sticker is comparing rated payloads on the dealers lot.
Once that vehicle leaves the lot that number goes down with every item you add to the vehicle. The other tag that has been around for a very long time "the VIN" has very important information that many fail to understand. It has GVWR and individual Axle weight ratings. Both the Yellow and VIN have the minimum tire size to maintain the GVWR/Payload depending which sticker you are looking at.
The yellow does have the additional information of the Size and PRESSURE to carry the MAX payload.
I am assuming this is the one from Old-Biscuits Ram, you will notice the pressure stated is 65 psi on a LT 275/70-18E tire with a MAX sidewall pressure of 80 psi. The 65 psi will safely carry the load, and provide the best TRACTION and ride at max payload. If empty the rear pressures can be reduced.
Oct-09-2016 09:41 AM
Oct-09-2016 08:46 AM
Oct-09-2016 07:11 AM
Oct-09-2016 07:07 AM
tatest wrote:
Driver is not considered part of the payload, but there is a weight associated with that, probably something like 158 pounds (it makes more sense in metric, and comes from the airline industry). Any excess driver weight is payload.
Oct-09-2016 07:01 AM
Old-Biscuit wrote:Lantley wrote:
The 2824 is specific to that exact vin # and is the most accurate. It includes options and features that reduce the payload. The other numbers are model specific and apply to all generic builds of that truck
This is the correct answer.
Truck tire data sticker gives info pertaining to THAT Specific vehicle
The combined weight of occupants and cargo should not exceed XXXX kg or XXXX lbs
Example:
Actual weigh ticket of truck loaded up subtracted from GVWR will give you AVAILABLE payload
