Pre- turbo EGT's... what are you seeing?
d3500ram
Primarily looking for Dodge numbers, but let's hear from the Dmax and P-stroke crowd too. Post your temps (preferably pre-turbo temps) and the conditions under which those are achieved (camper on or off, flat terrain/ climbing, etc.) What's the max you ever hit?
We have a good cross-section of TC folks here so I am curious of what we'll see.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
16 REPLIES 16
Grit_dog
Navigator
Navigator
07 5.9 Cummins. With a healthy tune, I can race past 14-1500 deg pre turbo on steep grades at highway speeds. Truck keeps accelerating as fast as the egt guage.
with a tow tune I can top 1400 as well towing uphill highway speeds.
I keep it between 1300 and 1400 though unless necessary to drop the hammer for a short period of time.
towpro
ISBRAM wrote:
The minor mods on mine are 275RV injectors and a more open exhaust system. I still have the TSB# 18-11-99 power increase computer update that was later recalled because it was not epa certified. I only see 1225 to 1250 on a long pull at altitude loaded.
I have never backed out of the throttle because of temperature; I’ve been running it that way since 1999.
This is a nice reliable upgrade on the 24V ISB. I had this on my 98.5, Just keep checking your lift pump pressure every oil change so you know when it goes out, before it cost you a VE pump.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
Boatycall
pcoplin wrote:
I can hit 1300-1400 in a higher tune if I go willy nilly, but I adjust the tune on hills to stay right at 1200-1250 full throttle, which is usually the tow tune. 2001 7.3 Powerstroke.
Literally ditto....
I just came home from a week long trip to the North Idaho mountains, and pulling all the various passes between there and Seattle I regularly hit 1350 if I pushed it, but for the most part I kept myself from pushing the go-peddle past 1250.
It's been my experience from friends/family who run Dodges that they try not to go over 1200, where as the old 7.3L Fords can regularly hit 1350. I've had mine for almost 15 years, never had an engine or turbo related problem, just upgrades when I felt like it.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
-Kevin
'08 6.7, full deletes, 3 tunes available.
pulling up mountain passes I can hit 1350 for short runs but normally under 1k (with 4k of camper and 3k of trailer/toys
2008 Dodge Ram 3500 QC DRW auto
2008 AF 990
FS bags
Viair OBA
Rancho 9000XL's
ISBRAM
1999 Dodge Ram 2500 QC LB Cummins
2018 Airstream Flying Cloud 28RB
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
ScottG
Just keep in mind that if you run a tune that advances your timing, your max safe temp will be lower than stock.
Far_Roamer
On a long steep grade my pre-turbo temps can easily hit 1300 with the tune that I usually run. I have de-fuel set to that level but will usually back off the throttle a bit when I hit 1250, at least if it looks like it's going to be at that temperature for a while. Running on the flat at 70-75 mph I'm usually between 600 and 800 degrees. I read somewhere that the alloy used in Cummins piston melts at 1250, but with the piston riding in a cooled cylinder and being bathed in cooler oil maintains a lower temperature that the exhaust gas. I have also heard that guys using the Cummins for pulling competitions will often exceed 2500 degrees for brief periods of time.
Pete, Loretta, and Roxy (Retriever/Collie X)
05 Dodge Dually Quad Cab CTD
08 Snowbird 10-8
mooring_product
I would see 1400-1500 in the old Ford 6.0 drag racing or sled pulling. My 2012 CumminGs sees no more then 1200-1300 on a good long hill. Haven't raced or pulled with it yet.
Pete
2012 RAM 3500 Mega DRW. Stable Loads and Torklift tiedowns.
2006 Lance 881 Max.
JIMNLIN
My max wasn't going up steep grades but trying to maintain a 60 mph speed in a 38-45 mph head wind in western Kansas with my 13' tall 11200 lb 5th wheel trailer storage shed flat front square corners profile. Temps climbed into the 1300-1350 range so I backed off mph till the Cummins would run in the 1200 range all day long.
A side note on EGT's.
I've ran with a empty truck in 110-113 temps at legal 75 mph around here...then pulled into a rest area and had to idle for 6-8 min before EGT dropped to a safe shut down temps.
Rbertalotto
5.9 Dodge, juice with attitude tuner that I can program to any ETG I want and it "de fuels" at my setting of 1250 degrees. I set max boost at 29 pounds and turbo cool down at 350 degrees.
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
towpro
I went through that with my 98.5 and 2002 Dodges. My 2006 is bone stock and I don't care what the EGT's are anymore. I just run it like the engineer that designed the engine intended :). No more intercooler hoses blowing off, no more watching the EGT and not the road, no more black smoke screens to give diesels a bad (worse) name.
but on the old trucks I used to try to keep it below 1200.
2022 Ford F150
Jaxom
Similar to what has been posted, around 1200 - pre Turbo. It has probably spiked higher than that, but I try to keep it under 1200.
Highest has been with the camper, trailer w/ ATV & Jeep inside. Climbing the mountains to & from Moab w/ nearly 24,000 gross weight.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
ChooChooMan74
Neither of he big 3 wih my VM Motori, but i can push 1300 to 1400 on a big climb.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
Lancey
mildly tuned 12v cummins superduty here, loaded pulling long hills hard, 1300 or so, I also have an air switch to kill the boost signal to the AFC, so I can kill some fuel if I see the egt's start to go higher.
But for the most part I just take it easy and keep them around 1150 1200
2005 arctic fox 990 silverfox
2008 Silverado ltz drw duramax 6speed allison
1999 Kodiak k99 / 2008 ford f450 6spd manual. SOLD
2000 citation supreme SOLD
1989 camperette SOLD
1985 okanagan SOLD
1990 northern lite SOLD
1995 northern lite SOLD
1997 Kodiak k99 SOLD
